Engine dyno numbers >
Engine dyno numbers
Engine dyno numbers
Old 11-10-2004 | 04:11 PM
375stinger's Avatar
Default Engine dyno numbers
Dyno'ed two of three engines so far, one with 606 hp, other with 631hp. The engines were all just rebuilt with all the time in the dyno. Is that much of a difference in numbers pretty common?
375stinger is offline
Old 11-10-2004 | 07:56 PM
Mudball's Avatar
Default Re: Engine dyno numbers
That's about 1%!!!
Pretty darned good, IMO.
Mudball is offline
Old 11-11-2004 | 08:48 AM
Strip Poker 388's Avatar
Rob
I would think your average hp would be more important.
Would 25 hp say at 3500rpm make a difference in throttle position???insynk?
Strip Poker 388 is offline
Old 11-11-2004 | 11:20 AM
1% You Might Want To Recheck Your Math
JIMG is offline
Old 11-11-2004 | 12:04 PM
HiPerf2000's Avatar
that's what i was thinking
more like 4%.
I agree with strip. check avg.
HiPerf2000 is offline
Old 11-12-2004 | 07:09 PM
375stinger's Avatar
hawk 511ci bored to 551. 1050 diminators, same carburator was used for all engines. 2rd engines came in around 632hp. If i put the 606hp engine in th center wouldnt it be ok?
Old 11-12-2004 | 07:10 PM
375stinger's Avatar
nevermind 3rd engine came in around 632 hp
Old 11-13-2004 | 07:14 PM
JCPERF's Avatar
Should be within 5hp. 10 at the most.
JCPERF is offline
Old 11-13-2004 | 08:32 PM
mcollinstn's Avatar
Head porting differences (whether they are as-cast or have had port work done) will account for a few hp difference. CNC ported heads, cc'ed chambers, and individually degreed cams will result in very very little hp diff between otherwise identical motors.
30 hp is more than you'd like to see.
mcollinstn is offline
Old 11-13-2004 | 09:20 PM
Infomaniac's Avatar
Leakdown test the low HP engine? Any other differences?
Oil pressure, water temp, oil temp, BSFC?
Infomaniac is offline
riski bidness
3
04-26-2006 04:15 PM
stevesxm
43
12-22-2005 10:01 AM
FASTERDAMITT
07-19-2005 01:33 AM
puder
09-03-2002 09:11 PM
