1995 454 Magnum EFI internal specs??? >
Old 11-23-2004 | 02:02 PM
Wally's Avatar
Were doomed!
Default 1995 454 Magnum EFI internal specs???
OK, i'm sure this may have been talked about before but i cant seem to find anything useing the search no matter what combo i put in it......so my question is: What does a 1995 454 Mag EFI motor have in it??? Are the heads rec or oval port? forged crank? Good rods? Forged pistons? i know its a roller motor...fill me in here!
-Wally
Wally is offline
Old 11-23-2004 | 02:15 PM
BURNSMAZZ's Avatar
Default Re: 1995 454 Magnum EFI internal specs???
Everything you just said rectangular port heads,forged pistons,hydraulic roller cam,forged rods,four bolt mains,it's good stuff.
BURNSMAZZ is offline
Old 11-23-2004 | 02:52 PM
Wally's Avatar
Were doomed!
Cool thanks......do you know if it has a serpentine belt setup? or the v-groove still for that model year?
-Wally
Wally is offline
Old 11-23-2004 | 06:35 PM
Pat McPherson's Avatar
A 1995 is likely a Gen V not a Gen VI. I believe 1996 is the transition year.
It is easy to tell, does it have a 6 bolt or 10 bolt timing cover? If 6 bolts, Gen VI roller...
It has V-belts; my 1997 still has V-belts.
The rest you have right, rec heads and good forged internals...
Patrick
Pat McPherson is offline
JERSEY DEVIL
5
01-07-2008 08:58 AM
fbh-velocity
1
07-29-2007 03:49 PM
TURBOED
3
01-22-2004 10:03 PM
blown formula
31
06-10-2003 06:59 PM
obnoxus
2
02-18-2003 06:04 PM
