34'' SUPERBOAT Center Console !!!! >
Old 12-01-2004 | 07:30 PM
FX10's Avatar
These are the first pictures of the new 34'' Superboat center console. The pictures you are seeing are the plug, which will be used to make the new deck mold. They should be in production by early spring. It will have a full cabin liner. And as you can see, the cabin is quite a bit larger then a cuddy. To make boarding and unloading easier, there are steps leading from the cockpit sole to the deck. There is also a bench seat with storage adjacent of the steps that can be used to store fenders and ropes, or whatever.
Fuel capacity will be in the area of 300 gals. Since this is a lightweight composit hull, we're hoping that with a pair of 300 hp Yamahas, she''ll do in the ballpark of 75 mph.
I''ll keep the progress pictures coming.
Rick
Attached Thumbnails 34'' SUPERBOAT Center Console !!!!-dscn2377.jpg   34'' SUPERBOAT Center Console !!!!-dscn2370.jpg   34'' SUPERBOAT Center Console !!!!-dscn2369.jpg
FX10 is offline
Old 12-01-2004 | 07:49 PM
SUPERBASH's Avatar
Default Re: 34'' SUPERBOAT Center Console !!!!
JC's new Fire Island Ferry "The Kismet Express"...
-Go Merc Verado J.C....screw the yamahahas.
SUPERBASH is offline
Old 12-01-2004 | 08:19 PM
Stormrider's Avatar
JC Performance Engines
I'm guessing 8ft beam?
Stormrider is offline
Old 12-01-2004 | 08:28 PM
SUPERBASH's Avatar
34's are 8'-6" same hull...new deck.
Old 12-01-2004 | 08:54 PM
tripps's Avatar
What happened to jenifer?? tripps
tripps is offline
Old 12-02-2004 | 04:11 AM
Superbabi's Avatar
Rick, Thats One Big Fishing Rig. You And Jc Going Fishing ? Lol,,,,,,,,,
Superbabi is offline
Old 12-02-2004 | 11:32 AM
SUPERSTITIOUS's Avatar
I was inside it a month or so ago! Quite a bir of freeboard! I'm curious what the estimated weight will be?
SUPERSTITIOUS is offline
Old 12-02-2004 | 06:54 PM
FX10's Avatar
I believe it's around 4500 lbs. It's a lightweight hull with foam coring in the sides and balsa coring from the chine down. Pretty light for a 34'.
Rick
FX10 is offline
Old 12-03-2004 | 05:45 PM
GEORGE YURICK's Avatar
hey bash....quit ragging on the yamahas.. ..nuff said...
GEORGE YURICK is offline
Old 12-03-2004 | 06:57 PM
FX10's Avatar
You can get the 300hp yammis with a 6 year warrantee. Thats 1 of the reasons.
FX10 is offline
