TRS vs BRAVO >
TRS vs BRAVO
TRS vs BRAVO
Old 12-03-2004 | 10:58 AM
Default TRS vs BRAVO
Is the distance from the crank shaft to the prop shaft on a TRS the same as on a Bravo?
CN24 is offline
Old 12-03-2004 | 12:57 PM
IRONMAN's Avatar
Default Re: TRS vs BRAVO
I measured a little more than 2 inches shorter.
IRONMAN is offline
Old 12-05-2004 | 05:50 PM
I'm guessing that Ironman is saying that the Bravo is about 2" shorter from drive input C/L to prop shaft C/L than a TRS. That right?? --- JP
jpclear is offline
Old 12-05-2004 | 07:49 PM
Am I misunderstanding the question? What about the transmission?
Edward R. Cozzi is offline
Old 12-06-2004 | 11:06 AM
Crankshaft C/L and drive input C/L should be the same; transmission or not. I'm assuming that we are talking about a verticle dimension here. --- JP
jpclear is offline
Old 03-18-2007 | 12:00 PM
Can anybody get me Crank line center to top of Transom Plate on TRS vs Bravo, I know this question dose'nt make sense, but it will cure my curiosity. I have a picture that shows TRS mounted at the rub rail from the Factory, I would like an idea of where the X was stock.
27 MAGNUM is offline
towhead
Drives and Lower Units
2
03-07-2008 03:11 PM
dean51267
11
07-31-2006 04:10 PM
lost2a6
19
11-18-2005 12:09 PM
Excalibur
1
07-22-2002 07:28 PM
