Best way to fill "bolt holes" no longer used on transom >
Old 12-05-2004 | 08:15 AM
Formula Outlaw's Avatar
Default Best way to fill "bolt holes" no longer used on transom
Not quite sure the best way to fill four bolt holes that will no longer be used on my transom. My first thought is to cut a hardwood dowel the appropriate length, smear the inside of the hole with FG resin, and drive the dowel into the hole a sixteenth of an inch past the "plane" of the transom, then filling with Marine Tex?
Anybody got any better ideas?
Formula Outlaw is offline
Old 12-05-2004 | 10:28 AM
offthefront's Avatar
Default Re: Best way to fill "bolt holes" no longer used on transom
you crank that thing up yet ? The holes are about 1/4" ? 4 ? I would think the the dowel would work fine ...if you recessed it just enough so you could put some resin and then gelcoat you wouldnt ever know it was there .... Took BadNews out Friday for a cpl of hours ..ran pretty good ..maybe bad times are behind us ...
offthefront is offline
Old 12-05-2004 | 11:37 AM
cuda's Avatar
The dowel method is what I've always heard to repair them.
cuda is offline
Old 12-05-2004 | 12:42 PM
Charter Member #415
Stainless steel carridge head bolts are quick and easy. When the holes are that small it looks fine in most instances. Very often you see brand new boats with bolt heads exposed that are holding something inside the transom.
Magicfloat is offline
Old 12-05-2004 | 12:45 PM
Dowels it is... Thanks guys.
Spacers are ready and will pick up Monday. Looks like maybe Thursday trailer the boat up to "the Gusman's" shop to put it back together. That will also give me a couple of days to paint the spacers black.
I'm getting excited.......
Old 12-05-2004 | 02:03 PM
cuda's Avatar
Damn, and I thought I was slow at painting! A couple of days to paint the spacers????
cuda is offline
Old 12-05-2004 | 04:09 PM
Fine art takes time Cooderman, fine art takes time.....
The dowels are now in place with about an eighth/inch recess. Am going to use white Marine Tex to fill it basically even, then white gelcoat to finish it off and feather and buff.
Got a few more little "dings" to fill while I'm doing the gelcoat thing. I've never really done gelcoat before so it'll be interesting how it comes out.
Old 12-05-2004 | 06:19 PM
cuda's Avatar
Tell me about it. In a couple months, it'll be a year I started painting this one. After ragging you about two days to paint the spacers, I actually got out and painted on it for the first time in well over a month. I think I'm done with the hull now, unless I decide to paint a black stripe on the transom. I'm ready to get this thing out of my garage!
Attached Thumbnails Best way to fill "bolt holes" no longer used on transom-guns-005.jpg
cuda is offline
Old 12-05-2004 | 08:02 PM
Remember, I gotta prime the spacers then finish coat, so two days ain't THAT bad. LOL.
This is getting so so close to finally being back on the water.
Old 12-05-2004 | 08:36 PM
CBlakeNS's Avatar
Good luck man, get some pictures when you are done.
CBlakeNS is offline
