Oil Changers
Old 12-05-2004 | 04:27 PM
Hot Duck's Avatar
Default Oil Changers
Is there anybody here using one of the permanently mounted oil changing systems in their boat? If so, what brand and how do you like it? I have always used the portable setup that is basically a 5 gallon bucket with a pump on top, but I am considering installing a system in the boat to make things a little easier and a little more convenient.
Also, has anybody figured out a way to make one of these permanent systems work for the transmissions as well? We have another one of the portable bucket/pump setups for the transmissions, but I figure that it can never hurt to feel out all of the options.
Hot Duck is offline
Old 12-05-2004 | 04:56 PM
Default Re: Oil Changers
Reverso has a nice set-up that you can manifold for the trannys too. Good, strong pump, nice hardware and a price that's fair.
Edward R. Cozzi is offline
Old 12-05-2004 | 05:14 PM
mr_velocity's Avatar
Install a set of prelubers then you can have oil pressure before you start and also drain the oil with a flip of a switch. It's the only way to go!!
mr_velocity is offline
Old 12-05-2004 | 08:38 PM
Hot Duck's Avatar
Edward R. Cozzi: I have looked at Reverso and it seems to be a nice setup. Are you using one of these systems?
mr_velocity: I have also been looking at pre-lubers, but never considered them for oil changes. The only one that I have looked at was made by Master Lube, but I don't see how this particular setup will pump out the oil to change it. It seems that these only move the oil from the pan to the pre-luber when the engine is running. What brand are you using?
Thank you both for the info.
Hot Duck is offline
Old 12-06-2004 | 02:12 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
HD, I just have the Mercury drain kits on my motors. They come from the factory that way. I realize you don't have stock power, but no reason they would not work. Its simple and nothing to break. It has a line that you extend out the bilge drain hole and drop into a container. I usually let mine drain for a couple days during the week, and then refill before the weekend. I think the pre-lubers are sweet, but they are pricy and take a while to install. If you want it to drain a little faster, warm up the engine first on the hose. The kits have been discussed on here before and cost about $50 per motor.
Sydwayz is offline
Old 12-06-2004 | 02:57 PM
Not sure of the brand, it is an electric pump that pull the oil from the pan and pushes it throught the oil filter. It has a quick disconnect fitting that I can pull to pump all the oil out. I need to look tonight, they came with a module that would automatically start the pump when you turned the ignition key on and run again after you turned it off, I guess for turbo applicaitons. I removed that and just use a toggle switch.
Old 12-06-2004 | 03:11 PM
I have this set up and love it! I have twins and I just ran tubing from the oil pans to the reverso manifold, to the pump, and from the pump to bucket. You can drain both motors at once, change filters, refill all in about 15 min. The pump can also put oil back in.
Pure Energy is offline
Old 12-06-2004 | 03:22 PM
Here you go, this is the only way to go. Easy oil changes and never a dry start.
http://www.pre-luber.com/
My system is 10 years old now, never a problem. I think the company has changed hands over the past few years.
Old 12-06-2004 | 04:02 PM
Corona
Trick Marine makes a really nice pre-oiler system that you can also use for oil changes. Money well spent.
Old 12-07-2004 | 12:11 PM
Hot Duck's Avatar
Thank you all for the information. All of these setups look to be easier than the old pump on the bucket!
Hot Duck is offline
