Any 6 liter ford diesel problems ? Exhaust leaks common ??? >
Old 12-08-2004 | 03:51 PM
Default Any 6 liter ford diesel problems ? Exhaust leaks common ???
We have an 03 we are selling ,to get an 05 , that just developed a terrible stink of exhaust in the cab . I can't find it .....
Ford says it is a common problem ..... they are fixing it Monday .
I had a customers truck a couple weeks ago that had a SEVERE exhaust manifold leak ! It sounded like a giant air compressor with a leak ! I couldn't see it ,I could here it and feel air blowing all the place under the hood , so I don;t know if it was a cracked manifold or just the gasket .
HAs anyone else seen this problem . Just wondering how common it is . And some people may not realize they have a problem , my cusomers didn't ! They thought it was normal to smell diesel soot in the cab ........
boot is offline
Old 12-08-2004 | 03:58 PM
SeaRay Jim's Avatar
Default Re: Any 6 liter ford diesel problems ? Exhaust leaks common ???
The flex "Y" pipe into the turbo sometimes cracks and lets the stink out. However, just before it turned cooler here, I was noticing a stronger "funky" diesel smell when I came to a stop with the A/C on (especially after a hard run). It wasn't consistant but was becoming more frequent. Seems to be somewhat of a mystery.
SeaRay Jim is offline
Old 12-08-2004 | 04:48 PM
Jassman's Avatar
Have an 04 and now 05, no problems with either, on the exhuast that is. Jeff
Jassman is offline
Old 12-08-2004 | 06:40 PM
buck183's Avatar
Boot,
As you well know you and I are in similar lines of work.
We move a lot of those through our shop. I have not heard of this yet from any of my customers. This would include my own. Mine is an 03. You know, the year that everyone says don't buy. Of all the ones I have built up for customers mine is the fastest and least problematic.
Buck
buck183 is offline
Old 12-08-2004 | 09:43 PM
vette131's Avatar
it's pretty common but not much fun to fix. 6.0's are a real beoch to work on.
vette131 is offline
Old 12-08-2004 | 10:01 PM
Scott's Avatar
Charter Member #30
I had my down pipe replaced under warranty. I could not sit in my cab for very long before I was choking on fumes. 2004 F-350 CC Dually
I have Steps & Bubbles!
Scott is offline
Old 12-09-2004 | 05:43 AM
ofshore's Avatar
No problems with mine so far oh!! except for the price of diesel
ofshore is offline
Old 12-09-2004 | 09:23 AM
From: A tree somewhere in the woods in Clarcona Fl.
Cured mine,,Installed a Bassani 4" system with downpipe & cat eliminator..
Slick02 is offline
Old 12-09-2004 | 09:36 AM
SeaRay Jim's Avatar
I've a Magnaflow on mine. I've been told that the funky diesel stink (kind of waxy smell) as opposed to regular exhaust smell, is actually the CAT. I have my CAT welded back in and wondered if it was that? Little extra fuel tuned just right and stop after a pretty good run??? Could be.
Old 12-09-2004 | 10:38 AM
Charter Member#1545
Joe, although most of exhaust leaks are covered by warranty, we have seen a half dozen or so out of warranty that have developed leaks. Most were at the flange. 2 had broken flex pipes.
Sam
Neverfastenuf is offline
