New Volvo deal
Old 12-13-2004 | 05:04 PM
Default New Volvo deal
http://www.donzi.net/forums/showthread.php?t=37764
Pismo10 is offline
Old 12-13-2004 | 05:16 PM
J-Bonz's Avatar
Default Re: New Volvo deal
That rubber boot around the thru hull fittng looks very similar to the OMC's engineering marvel, the stringer!!! Makes me want to run away as fast as i can from this product!!!
Just kidding, It looks very interesting
J-Bonz is offline
Old 12-13-2004 | 11:16 PM
mopower's Avatar
Toxic FORMULA
Doesn't look like anything I could use where I boat. Too much crap in the water
mopower is offline
Old 12-14-2004 | 07:57 AM
C_Spray's Avatar
Diamond Member #001
Definitely the result of some big-time different thinking from Volvo. It's strictly an alternative for inboard boats. The big advantages are packaging, weight, there's nothing in front of the props to screw up the flow of water to them, and (biggest of all) the props are directly in line with the water flow. The drive leg is bronze (!!), not aluminum, so it's super-stout. In the case of a really bad impact, it's also designed to shear off at a pre-engineered point that won't let water into the boat. Just like a sterndrive, the boat must be engineered to take the thrust loads where the drive goes through the hull. Unlike the OMC stringer drives, the sealing rings are not bellows - they're just giant o-rings. It's also completely fly-by-wire, including the steering. The other neat thing is that your entire propulsion package comes from a single manufacturer: no finger-pointing in the case of warranty/service issues. Combined with their new diesel stern drive, VP's got some neat stuff onthe market right now.
In the pictures below, the engines are towards the FRONT of the boat. Yes - the props face forward.
Attached Thumbnails New Volvo deal-volvo_penta_ips_side.jpg   New Volvo deal-volvo_penta_ips_3.jpg   New Volvo deal-volvo_penta_ips_cutaway.jpg
C_Spray is offline
Old 12-14-2004 | 08:35 AM
Stormrider's Avatar
JC Performance Engines
I'm assuming the engines need to be mounted toward the stern, as opposed to straight inboard where the engines are mounted forward.
Stormrider is offline
Old 12-14-2004 | 08:44 AM
C_Spray's Avatar
Diamond Member #001
That's the idea - the engines go in the lazarette, and all the space under the salon becomes available for storage and staterooms.
C_Spray is offline
Old 12-14-2004 | 08:48 AM
fund razor's Avatar
I will admit it.
I kinda like Volvo.
But then again, I have OMCs.
fund razor is offline
Old 12-14-2004 | 09:23 AM
Give it a few years until they work out the bugs, then it will be great in certain apps.
Pismo10 is offline
Old 12-14-2004 | 09:26 AM
OK, I'm going to turn around the lower on my bravo and run the propeller facing forward!
cobra marty is offline
Old 12-14-2004 | 10:28 AM
C_Spray's Avatar
Diamond Member #001
Marty - make sure you don't try to use the thru-hub exhaust in that case....
C_Spray is offline
