Blueprinting hulls? >
Blueprinting hulls?
Blueprinting hulls?
Old 12-16-2004 | 08:46 AM
Default Blueprinting hulls?
Hello all, I was wondering what the cost is for blueprinting a 29 foot scarab hull. Also, what should I expect to gain in mph. Is it worth the time and expense? What is involved in the process and would it be a good time to have some dings and gel cracks repaired? Just curious, because I dont expect to pick up much speed; but having a straight hull would make my future mods more effective. Any info would be appreciated.
perfboat is offline
Old 12-16-2004 | 08:39 PM
Superbabi's Avatar
Default Re: Blueprinting hulls?
Having 30 Y2k Superboat Built Now. This Hull Will Be Blueprinted At Factory Before Rigging. Check Out Treads At Superboat Site. ( Superbabi ) Check With Rick. ( Fx-10 ) Top Man At Superboat Inc. Gary
Superbabi is offline
Old 12-16-2004 | 09:44 PM
monsta
Blue printing can have as much as a 10 mph gain on some hulls. Not cheap, and should b done if bows, hook's , or un-even surfaces are noticeable and high speeds are expected.
Old 12-17-2004 | 06:04 AM
Steve_H
prolly a stupid question but exactly how is it done?
alot of sanding , laser measuring?
Old 12-17-2004 | 08:47 AM
Hey, Steve H, thats not a stupid question at all. That was part of the reason I asked about blueprinting in the first place; to see if it was worth the time and trouble to have someone do all that to my hull. I am still wondering about the cost. Also, is there anyone in Texas or near Houston that can perform the work.
perfboat is offline
Old 12-17-2004 | 10:07 AM
BRUCE SEROFF's Avatar
29 footer should be in the range of 3- $5,000. Depending on how bad the hull is. Could be as high as 10k
BRUCE SEROFF is offline
Old 12-17-2004 | 10:09 AM
You might try this guy. Name is Joe he is in Flower Mound Tx it's in the Dallas erea.
214-679-1089. Give him a call and get some references.
russ is offline
Old 12-17-2004 | 12:19 PM
Hey Russ, Thanks I appreciate the info. I'll give him a call. From the looks of the price, I might be better off going with my other option...Whippled 502. At least I can do the mechanical work myself. Fiberglass work looks scary!
perfboat is offline
Old 12-17-2004 | 12:21 PM
Plus, you need to turn the boat upset down, to do it right.
Old 12-17-2004 | 07:33 PM
FX10's Avatar
Make sure the guy is experienced with blueprinting. Talk with customers of his to verify the results of his work.
There are many different ways to blueprint a hull.
What attitude does your hull have now ? Are you satisfied with it ? Is it to flighty, or is the bow not getting up enough.
These are all things to take into consideration when having your bottom blueprinted. Whether your having a plain straightening job, or a rocker put in to give you more bow lift. Having the wrong blueprinting done will give you no increase in speed. Most hulls are safe with a straightening job.
Rick
FX10 is offline
