gm bowtie block >
gm bowtie block
gm bowtie block
Old 12-16-2004 | 08:41 PM
johnnyboatman's Avatar
Question gm bowtie block
what is a gen4 bowtie block worth good shape 60over?
johnnyboatman is offline
Old 12-16-2004 | 08:49 PM
tjthor
Default Re: gm bowtie block
Johnnyboatman
I use two of the same blocks. I have had one since 1991 and it is now 35 0ver and I bought a brand new, never touched mate to it recently for 1500 canadian. Your block has less life in it so maybe this will help you make an offer
Old 12-16-2004 | 08:58 PM
just bought 2 30 over, fresh bore 6 months ago for 1100ea. Definately less than 1000.00, as aftermarket will cost around 1800.00, these are nice blocks and much beefier than gen 6.Good luck
greencard is offline
Old 12-17-2004 | 04:27 AM
Linster's Avatar
Off the Radar
.060 over what? If you are talking 4.560, the walls are very thin, and at there limit. The Gen 4 Bowtie was only designed to be bored to 4.50 with a .030 overbore. When GM came out with the Gen V bowtie, they increased the cylinder bore thickness to allow a 4.60 bore. I have seen two Gen 4 bowties at 4.600 bore and the walls were paper thin. They are real old blocks, I would not give over $500 each for them. Personally, I would not want them. I would buy new 502 blocks before that. Merlins or Darts after that. A 502 block has thicker cylinder walls than the Gen 4 bowtie. The decks have larger water passages.
Linster is offline
e8411a
29
03-20-2010 08:19 AM
oreo11zeus
Wanted
3
04-09-2008 04:27 PM
oreo11zeus
General Racing Discussion
0
06-14-2007 10:41 AM
unbroken
7
11-30-2006 06:04 PM
Gassticks
03-18-2002 09:48 AM
