What model outdrive is this?
hard to tell cus of the angle its at but i'm gonna go with alpha the upper gear case looks to small to be bravo, thaat and teh baot has the littel gimpy trim tabs and they can usually be foudn with alphas
AND that prop loosk lieka revolution not a bravo1 4 blade. And revs are usually foudn on alphas.
Pardon me, while I whip this out!
bravo 1 one the back cover bolts give it away. it is tricky with that picture though. the tie bar also gives it away an alpha one gen II uses e-clips and push on plastic end caps.
