whats up with 2 power steering pumps and 1 is a dummy? >
Old 12-19-2004 | 11:15 AM
BajaRunner's Avatar
Default whats up with 2 power steering pumps and 1 is a dummy?
I just bought a 29 baja outlaw. On its maiden voyage, a power steering pump springs a leak, and starts whining. my power steering still works fine so i call a mechanic and he says one of them doesnt do anything?
so i put a new belt on bypassing the pump.
1. is that bad?
2. why would they put on an extra pump to do nothing?
BajaRunner is offline
Old 12-19-2004 | 11:27 AM
HiPerf2000's Avatar
Default Re: whats up with 2 power steering pumps and 1 is a dummy?
merc ships all motors with power steering pumps since they don't know if it will be for a boat with single or twins. It only takes one pump to work the steering, so when the factory installs them they will rig the system off of one pump and usually just take the belt off the other (non serpentine setups).
It's good to leave it on there in case your working pump takes a dump. you have a spare that you can swap to the other side.
HiPerf2000 is offline
Old 12-19-2004 | 11:44 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Fountain uses both pumps. This way we will always have power steering, regardless of which motor is running. Don't know why all builders do not do this.
US1 Fountain is offline
Old 12-19-2004 | 05:24 PM
Crazyhorse's Avatar
It's a cost that some builders don't want to eat, so it's offered as an option. There's a shuttle valve in the system to shut off the fluid from the non-functioning pump/lines.
I'll agree that it's a great option to have.
Crazyhorse is offline
Old 12-19-2004 | 05:31 PM
skaterboy's Avatar
Ever come home on one engine with a twin engine set-up ???? Its always a better idea to have both pumps working all the time, especially if your trying to dock on one engine that does not have the power steering.
skaterboy is offline
EagleXP30
3
11-26-2007 09:51 AM
boatman747
19
05-01-2007 06:08 PM
bobkatz
3
03-07-2007 05:17 AM
LubeJobs42
06-04-2006 10:32 AM
Raypanic
6
01-06-2003 10:00 PM
