Closed Cooling Diagram >
Old 12-21-2004 | 12:06 AM
Default Closed Cooling Diagram
I'm too lazy to figure it out otherwise than asking y'all but I want to back flush my closed cooling 496ho's. Which hoses do I disconnect to attach the water hose to and which do I undo to let the CRa_p out? Anyone with a diagram out there?
Thanks.
LHC30Victory is offline
Old 12-28-2004 | 05:28 AM
Default Re: Closed Cooling Diagram
I do not have a diagram available, but the easiest way I have found is, remove the lower hose on the right side of the main heat exchanger ( facing rearward). It is about 1 1/2" diameter. Find a suitable fitting that can be clamped in the hose. I found one at the local hardware store that would attach to a garden hose. Then remove the 2 blue drain plugs from the seawater pump. Turn on the water. I do this several times a year. you will be surprised how much debris will come out.
Island Hopper is offline
Old 12-28-2004 | 01:23 PM
does that clear out the oil cooler and heat exchanger as well?
Old 12-28-2004 | 01:44 PM
It will flush the oil cooler. The heat exchanger has plates on both ends that can be removed, and flushed by spraying water through it. I have rarely seen any debris here. Debris will usually stop at the oil cooler before it reaches the heat exchanger. In any case it only takes a few minutes to do both.
Old 12-28-2004 | 07:55 PM
Thank you for your replies. this will help a bunch.
Have a save and happy new year!
Pokher Ace
8
10-17-2008 07:22 PM
Wodster69
8
04-23-2008 08:55 AM
sandcraft
10
04-05-2006 09:44 PM
ROADHOG
5
12-20-2004 01:25 PM
24outlaw540
1
05-01-2004 12:57 AM
