ported or aluminum heads >
Old 01-03-2005 | 07:54 AM
Default ported or aluminum heads
What would be better porting a set of iron heads or going with new aluminum ones?
Application will be a Whippled 540 and my builder wants to have mine ported and I see and hear of a lot of people just buying new aluminum ones...what are your thoughts?
thanks
thegreygoose is offline
Old 01-03-2005 | 09:07 AM
Default Re: ported or aluminum heads
I would think the Aluminum heads would be better for heat dissipation since your talking boost.
Back4More is offline
Old 01-03-2005 | 09:19 AM
Originally Posted by sutphen30
depends on how much hp you want,,up to 800hp,you could stick with the stockers.also,if you have some xtra cash,then you could buy aluminum.
So there is no advantage to porting instead of Aluminum?
I think he quoted me 1200.00 to port
These are some of the parts he will be using...any suggestions?
J & E Blower Piston
Hi Volume Mellings Oil Pump
Scorpion Roller Rocker Arms
Lunati Custom Grind Flat Tappett
Scat H Beam rods
ARP Rod Bolts
Old 01-03-2005 | 09:27 AM
the newer aluminum heads will get you there easier.pocket porting the iron heads should suffice,but the cool factor of aluminum heads won't be there.
what are the ballpark specs of the cam.
I'll find out
Old 01-03-2005 | 09:41 AM
PatriYacht's Avatar
Jim Valako here on the board can do some great work on those heads. I think he would be in the 1200.00 range also. Aluminum would be better but a lot more money. A set of cnc or hand ported heads set up for marine use is about 3000.00. If you want the best have Jim port a set of Dart 320's. They will flow 400 intake, 300 exhaust at .7 lift and very well at lower lifts too. www.valakoraceheads.com
PatriYacht is offline
Old 01-03-2005 | 09:47 AM
The site is expired...
So it's about 3k for aluminum heads vs 1200 to have mine ported...is it worth the extra 1800? Where will I see a difference? I'm only looking to make 800 hp.
Old 01-03-2005 | 10:02 AM
Smitty's Avatar
Add a few $$$$$ to that 1200.00 for new valves. You need Inconel exhaust valves if you are supercharging that motor.
Smitty is offline
Old 01-03-2005 | 10:15 AM
PatriYacht's Avatar
A 540 with the new large single Whipple (3300cc?) and ported Darts will make 900-1000 hp. The iron heads will make 100 to 150 less.
Hy-Velocity
3
04-11-2005 07:59 AM
splashandburn
68
03-22-2005 08:07 PM
dowhat
4
03-10-2004 02:12 PM
Dave1972
6
12-09-2003 02:16 PM
timucin
8
09-29-2002 11:43 AM
