Listen to this blown 383 small block >
Old 01-18-2005 | 02:48 PM
Default Listen to this blown 383 small block
Guys this is what I get up in the morning for and I always say I wouldn't want to do anything else . This a project for a friends single engine 26 cat this engine on the dyno made 9 PSI of boost on pump gas and never set the det sensor off not even once. We changed the shape of the quench area in the combustion chamber when we ported them and this thing is a dream even how it idles at 900 RPM with 28 degrees of total timing . Tommy the owner had us install billet caps on a bowtie gm block he had us sonic test.Here are some pics for the gear heads.
there is the block with the plate being finished
and there is the finished product 736HP at 6500 RPM and 647 ft lbs at 4600 this one is for the small block guys hope you like.Sincerely Laz Mesa
P.S. Come see us at the boat show booth 4184
Attached Thumbnails Listen to this blown 383 small block-hpim0336.jpg   Listen to this blown 383 small block-hpim0340.jpg
MESABALANCING is offline
Old 01-18-2005 | 05:10 PM
BajaRunner's Avatar
Default Re: Listen to this blown 383 small block
those are impressive numbers.
BajaRunner is offline
Old 01-18-2005 | 06:55 PM
offshoredrillin's Avatar
Thats beautiful, I have a 383 interenally balanced stroker sitting on a stand w/ edelbrock6071 angle plug heads, beautiful motor, supercharged w/ vortech should be over 650 hp tons of torque. love a stroker motor!!! Runs on pump gas very easy idle!!
offshoredrillin is offline
Old 01-18-2005 | 09:59 PM
thats my bike
customryder is offline
Old 01-19-2005 | 12:09 AM
Strip Poker 388's Avatar
Rob
Kinda looks like a car motor with the short snout and just one v belt for the water pump.
I would guess it is a bravo boat ? what about the alternator,power steering and water pump?
Laz give us motor heads some more info.Like what heads ,cam type, carb size,,Did ya try anymore timing,How low did ya pull it down to.
Laz your teasing us
Strip Poker 388 is offline
Old 01-19-2005 | 04:05 AM
Iggy's Avatar
The damn blower is as big as the block!!!
Looks like a 6-71? Why so big on a 383?
I'll say one this, it sure is impressive looking.
Iggy is offline
Old 01-19-2005 | 07:35 AM
Registered User
It is a 8-71, I was there to see the dyno pulls , rock solid
MIAMIBOYZ is offline
Old 01-19-2005 | 08:02 AM
Laz your teasing us
Strip the heads are Brodix -11s and it actually is a two groove pulley but we didn't have the alternator or bracket back from the cnc shop were running the new MSD billet alt. I pulled it from 3000 to 5600 on the initial pull since I didn't know how the 750s were going to react its got a mechanical fuel pump and I didn't want to lean it out after I saw it was all good I turned it up to 6500 starting at 3000 again the cam is a custom from Cam Motion and its 275 272 @ .050 and .720 .690 lift solid roller. on a 112 lsa.
Old 01-19-2005 | 08:05 AM
rmbuilder's Avatar
MarineKinetics
Laz,
Those are outstanding numbers! With that 1900 RPM spread from peak TQ/HP whatever boat that motor goes in is going to pull like a rocket. Look foreward to seeing you in Miami.
Bob
rmbuilder is offline
Old 01-19-2005 | 08:09 AM
I did try more timing and the power fell off big time remember its on pump gas thats no crap. I'm trying to figure how to put the video in so you guys can see it and listen to it . It really sounds bad ass specially around 6500RPM
