How much is a blown XR worth? >
Old 01-23-2005 | 05:10 PM
Panther's Avatar
Frank's Marine Service
Default How much is a blown XR worth?
My friend blew an XR drive over the summer and I asked him if I could have it so I can build a spare for my boat. He asked me to give him whatever $$$ it is worth. I told him I would first tear down the drive and see what the problem is and then let him know what I will pay.
I spent the better part of the afternoon tearing down the drive. It has a broken upper drive shaft and a twisted down shaft. All gears, bearings, top cap and cases are in good condition.
What do you think fair value for the drive is?
Panther is offline
Old 01-23-2005 | 06:07 PM
'05 Concept SF23
Default Re: How much is a blown XR worth?
Call Doller Offshore and ask them what they pay for cores. This should give you a starting point.
f311fr1 is offline
Old 01-23-2005 | 09:00 PM
Sean H's Avatar
A to Z
when he blows the next one, start sending them my way....
new ones are like 7500... i have seen some takeoffs for 4k, i would say 2500-3000 if that is all you have to replace....
Sean H is offline
Old 01-24-2005 | 01:00 AM
articfriends's Avatar
Make sure the tower isn't damaged or you will have to replace upper housing or possibly have broken tower bored out at max machine worx,Smitty
articfriends is offline
Old 01-24-2005 | 08:52 AM
Panther's Avatar
I checked the tower and everything looks good but ofcourse if I decide to fix it I will go thru with a fine tooth comb.
The upper drive shaft twisted off at the bottom just above the splines so the upper didn't shift, it broke off clean.
Panther is offline
Old 01-24-2005 | 08:53 AM
Panther's Avatar
thanks, I'll do that!
Panther is offline
Old 01-25-2005 | 12:42 PM
Panther's Avatar
Now I'm thinking about fixing the upper and keeping it for myself and selling the lower. I'll probably replace the drive shaft and then sell because I can't use the lower for my application anyway.
Panther is offline
Lofty
07-26-2007 06:25 PM
30Spectre
04-15-2006 09:19 AM
Strip Poker 388
12-11-2004 04:52 PM
bajah2x105
22
07-16-2002 04:30 PM
