Db Testing???
Old 01-27-2005 | 12:44 PM
Default Db Testing???
Is There A Sound Level Restriction On Senaca?? And Will It Be Enforced At The Poker Run?
PROMAN is offline
Old 01-28-2005 | 12:15 AM
Need-the-Speed's Avatar
Xtreme Cooler Test Dumby
Default Re: Db Testing???
Proman
There is a 90 db. level on Seneca as well as the rest of the State. However, during the Poker run the SPBA obtains a Federal water way Regatta Permit, which indeed grants us permission to run with-out mufflers for the duration of the wknd. This is the same permit that is required to hold a racing type event.
The only thing you should be getting nervous about is that incredible Auction on Sat. night. See you at the run! Bill
Need-the-Speed is offline
Old 01-30-2005 | 06:47 PM
RLW
Is the 90 db measured at idle or at speed?
How far away is the db meter placed?
RLW is offline
Old 01-30-2005 | 10:40 PM
RLW
The 90db. test is done at idle. The db. unit is placed approx. 3ft. back (from transom) and 3ft. up (from swim platform). There is a 2% +/- margin of error allowance. I hope that answers your quest. Bill
Old 02-01-2005 | 07:56 AM
RLW
Bill,
Thanks for the reply. Hopefully get over to Seneca this year to check out your club.
I spend alot of time on Canandaigua Lake. I have met the Nader Brothers at a friends house, here on Honeoye Lake.
Russ
RLW is offline
Old 02-01-2005 | 01:14 PM
RLW
Hope to see ya'. The Naders boys are good bunch. We have a drink or two (...or three, or four) on occassion. You should make it over for the Pirates Run. I think you might have a good time. Bill
skaterdave
OPA/The Jersey Boyz
2
05-22-2008 08:40 AM
SHARKEY-IMAGES
08-10-2003 04:31 PM
OPBMiniatures
Baja
2
02-21-2003 09:35 PM
