Livorsi tachmomters
Old 01-29-2005 | 09:57 AM
PorscheSpeed's Avatar
Default Livorsi tachmomters
Does Livorsi make tachometers for Diesel engines? if that, can you get a mechanical tach?
PorscheSpeed is offline
Old 01-29-2005 | 10:04 AM
Chris L's Avatar
Default Re: Livorsi tachmomters
Most diesel engines today use pulse adapters. A electronic device that the tac drive turns that sends the pulse to tachometer. Allows you to use any tachometer head you want.
Chris L is offline
Old 01-29-2005 | 10:10 AM
Not this one. its a cable that runs from the alternator to the Gage. Old school
Old 01-29-2005 | 10:21 AM
Chris L's Avatar
The end of the cable has a threaded coupler on it ? Undo the cable at Alt. screw the electronic tac adapter on Alt. Bingo! Some put the tac adapter in the dash. just undo tac cable from tac and put elecronic tac adapter on then wire up any tac you want. The electronic tac adapters we use are Stewart Warner's if I remember correctly.
Chris L is offline
Old 01-29-2005 | 10:30 AM
that might work. SO where do I get one of these adapters? on then theres still the question of does livorsi make a Diesel tach?
Old 01-29-2005 | 10:33 AM
heres a pic of the cable. Best i can do. cant get to the one on the truck. too cold to go out and fukk with it
Old 01-29-2005 | 10:37 AM
Chris L's Avatar
The last ones we got from NAPA they called it a sender kit Part# 701-1510
Can't help you with the tac head question.
Chris L is offline
Old 01-29-2005 | 10:42 AM
thanks! hopefully too old will pitch in here and fill me in
Old 01-29-2005 | 02:52 PM
Ttt :d
Old 01-30-2005 | 05:24 PM
pachangalpina's Avatar
Have you contacted Livorsi? Their website list them.Livorsi Diesel Tach
pachangalpina is offline
