wheel mag lock removal
Old 01-29-2005 | 07:55 PM
Default wheel mag lock removal
I have lost my key for my wheel locks on my trailer (dumb huh?) and was wondering if there is a trick way to remove without damaging my aluminum wheels. I have tried vice grips and they just slip off as the lock is tapered out. It is harden steel and I believe it is made by Mcguard.
Dirck W Gomez is offline
Old 01-29-2005 | 08:13 PM
Fountainclimber's Avatar
Default Re: wheel mag lock removal
A Call McGard, they sent me a key overnight if you have the lock number.
B Weld a new nut to the McGard nut.
C Drill two holes for pins for a spanner wrench. You'll need a few carbide bits.
I know you tried vise grips but how about using a die grinder to make some flats on the nut?
Good luck!
F
Fountainclimber is offline
Old 01-29-2005 | 08:18 PM
MACDAD260's Avatar
Charter Member #818
Any good tire store or repair shop will have a set of wheel lock removal tools. They might charge you a couple bucks to remove your locks. That is one way to get them off without damaging your wheels. Or, if you want , you can buy the tools. About $100. PM me if you are interested and I can help you get them.
Good luck. Doug
MACDAD260 is offline
Old 01-29-2005 | 08:24 PM
mattjtowne's Avatar
Go to Sears... They have a kit for $25.... Its in the hardware department and is in a little red case... It has like 6 different sizes in it........
mattjtowne is offline
Old 01-29-2005 | 08:25 PM
Scott B's Avatar
Drive a cheap socket over the locknut, use a breaker bar to take it off...
Scott B is offline
Old 01-29-2005 | 08:33 PM
mattjtowne's Avatar
Its actually $29 and its part number 52165...
The socket works too if you get lucky and get one to fit the lock right.. McGard's are always a strange size.. We use this all the time to remove locks...... The teeth bite in as it turns where a socket wont...
Old 01-29-2005 | 08:52 PM
LubeJobs42's Avatar
I have a Snap on lug lock remover I never used. I can loan it to you. If want want me to send it Monday PM me your info.
LubeJobs42 is offline
Old 01-29-2005 | 09:12 PM
jordy's Avatar
That would be my suggestion if you have one lock per wheel. However, if every lug is a lock, I'd probably get the removal tools.
jordy is offline
Old 01-29-2005 | 09:40 PM
PorscheSpeed's Avatar
torch them off
PorscheSpeed is offline
Old 01-29-2005 | 10:06 PM
NASTY HABIT's Avatar
done the socket thing ...worked fine
NASTY HABIT is offline
