Trim Tab Mounting >
Trim Tab Mounting
Trim Tab Mounting
Old 01-31-2005 | 02:57 AM
VIPER7's Avatar
Question Trim Tab Mounting
I am trying to find the corrrect mounting distance up from the bottom of the boat to the bottom of the trim tab itself. The tabs that I am inquiring about are Kiekafer k Planes. I do not know the part number but they are about 22 inches long. Any assistance with this info would certainly be appreciated.
VIPER7 is offline
Old 01-31-2005 | 09:14 AM
Default Re: Trim Tab Mounting
mine are approx. 3/4" up. I think I still have the mounting instructions, I'll check.
CN24 is offline
Old 01-31-2005 | 11:56 AM
VIPER7's Avatar
Aljolyn, If you find the mounting instructions I would certainly appreciate a copy of them.
VIPER7 is offline
Old 02-02-2005 | 07:23 AM
Found the instructions. There basically a template with hole sizes, pretty big, no way I can scan them. If you let me know what info you need I'll get back to you.
CN24 is offline
Old 02-02-2005 | 03:43 PM
Dave M's Avatar
Veteran: Navy
You might want to ask the manufacutrer of your boat. I'm noticing more boats with the tabs mounted parallel with the ground rather than parallel with the 'V' of the hull. I'm not sure what the reason is.
Dave M is offline
Old 02-02-2005 | 03:51 PM
I would like to hear about that. I have been curious of the advantages.
TxHawk is offline
Old 02-02-2005 | 07:48 PM
I saw a vee with the tabs mounted parallel with the ground and close to the drive. He said his boat was very sensitive to tab movement. His reason was, as the water comes out of the transom it is following the vee. when you activate the tab the entire surface of the tab comes in contact with the water. When the tabs are mounted horizontal the outer edge of the tab contacts the water first making slow response. The more you lower the tab the more surface contact, speeding the response.
CN24 is offline
Old 02-02-2005 | 09:26 PM
Harper220's Avatar
That doesn't seem right? I would be curious to hear more?
Harper220 is offline
Old 02-02-2005 | 09:56 PM
Sean H's Avatar
A to Z
fountain pr 42
Attached Thumbnails Trim Tab Mounting-pokerp.jpg   Trim Tab Mounting-pokero.jpg
Sean H is offline
Old 02-02-2005 | 09:57 PM
Sean H's Avatar
A to Z
gladiator....
Sean H is offline
