Time to replace the gimbal ring (2)
Well It is time to go get the boat from storage and drop it off to be fixed. Out of the 3 boats I have owned I never had this problem before. Both Gimbal Rings have to be replaced, do i have the motors pulled and change them that way, or do I buy mercruiser kits, that allow you to drill a hole that is visable and a threaded plug put in the hole, so you don't have to pull the motors.I guess I should be thankfull thats the only problem. What do you guys think??????
PWRQUEST
When I traded my 29 they noticed that I had a plug in one of my drice housings, and thought that I had ripped off that drive (hit something in the water)
I had to explane what had happened so that is something you will have to think about if you put in the plugs
Good luck.
Good luck.
QUEST - Have they identified a cause to the problem? Seems like you want to correct what caused the issue in the first place at the same time you replace them.
How did you know they were bad? Sound/vibration?
QWST - Why did you have plug?
-Wally
-Wally
Wally,
My mechanic said the nuts on the inside of the transom came loose over time, and that caused the problem. The other major problem is, the marina I had servicing the boat obviously is not as smart as I thought they were. The guy I have working on it now tells me that those nuts should be checked at least once a year to make sure thier still tight to specs. And once he replaces them I can check them 2 times a year and I shouldn't have a problem again. The problem is that it is not a cheap fix.
Rich,
If I go with the plugs, does it look like a sloppy repair?
I just hate to have both motors pulled when i don't have to.
If you were buying my boat and you seen the plugs, would you be afraid of purchasing it?
Wally,
There is about 2 inches of play in each outdrive, (they both move side to side without moving the sterring wheel)
What I don't understand about the problem is that there is no slop in the steering wheel when I am moving, and I didn't notice the boat wandering excessively at no wake speed. I didn't even know there was a problem until the end of the season when I took it to be winterized, and my !!!NEW BOAT MECHANIC!!! told me they were bad.
Calvin
Calvin
Originally Posted by PWRQUEST
Wally,
Calvin
Calvin
If that gets loose (which it does)you will get play back there,it has happened to me before.
as far as the nuts make sure you torque then to 53ft lbs and no more because you can stretch them if you over tighten then.its a good idea to check them twice a year along with greasing the engine couples with the special spline grease merc makes.
Wally,
Calvin
Calvin
Steering Arm
