Cup holders >
Cup holders
Cup holders
Old 02-15-2005 | 02:35 PM
Default Cup holders
Where can i find aluminum anadyzed cup holders to fit in stock location behind the front bolsters. Hole size is 2-7/8".
alpine99 is offline
Old 02-15-2005 | 03:39 PM
38SprtCruzKev's Avatar
Default Re: Cup holders
Try Trick Marine, that is where I purchased mine, do not be surprised if you need to open up the currents holes a little bit, I had to with all 4 of the ones I replaced.
38SprtCruzKev is offline
Old 02-15-2005 | 04:02 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Fountain uses a bastard size cup holder. All I have ever seen need to be opened to the standard 3"
US1 Fountain is offline
Old 02-15-2005 | 04:29 PM
dykstra's Avatar
Is making the opening difficult to do? Or is it just filing?
dykstra is offline
Old 02-15-2005 | 06:57 PM
nitrofever's Avatar
I used a roto-zip when I installed mine, not very hard.
nitrofever is offline
Old 02-15-2005 | 08:43 PM
Ginger or Mary Ann?
You can also just use a coarse file. Hardest part would be to keep the vinyl pulled back far enough w/o tearing at the slits. I was going to do my 2 on the back of the front seats, but the wood framing under neath is so close to not allow a larger cup drop in there, I was affraid to find out the hard way.
Old 02-16-2005 | 09:15 AM
dykstra's Avatar
Thanks for the info
dykstra is offline
Old 02-17-2005 | 12:57 AM
Innov500s's Avatar
Someone told me to try and paint the fountain cup holders with an anodized spray paint. I plan on trying it this spring when I pull the boat out of storage.
Innov500s is offline
Old 02-17-2005 | 06:06 AM
Ginger or Mary Ann?
Seen it done to aluminum, looks like the real deal. Don't see plastic giving the same results.
Old 02-17-2005 | 07:42 AM
pachangalpina's Avatar
I used the spray paint on the black plastic engine/side vents until I get my CNC billet ones made. You first spray a base coat of metallic silver and then top coat with a translucent color. Mine turned out very well and held up last season so well that I put off working on the new ones. A lot of the auto parts stores sell the rattle can paints to do this with.
pachangalpina is offline
