280 K Plane Installation Instructions & Templates >
Old 02-18-2005 | 04:17 PM
BajaBennett's Avatar
Default 280 K Plane Installation Instructions & Templates
Guys,
I just picked up a set of take off 280 tabs. Do any of you have a set of intall instructions and perhaps templates??? I would be very grateful if someone can help me out.
Thanks,
Dail
BajaBennett is offline
Old 02-18-2005 | 05:11 PM
Tonto's Avatar
Default Re: 280 K Plane Installation Instructions & Templates
Dail,
You don't really need a template. You can take a piece of paper and place it up against the transom plate and take a pencil and rub it over the plate, or take a exacto knife and cut the holes out, to make a template. Just make sure that you have the template facing the same way as the tab will go on the boat. The indicator cable will be a big hole. Make sure you try to drill the holes as straight as possible as they must all line up in order for the tab to go on straight, if not, you just need to make the holes a little oversized. Use "101 Silcon Adhesive" to mount the tab to the transom, if you use 5200, you'll never get them off without destroying the transom plate or gelcoat/paint on the boat. I hope this helps.
Robert
Tonto is offline
Old 02-18-2005 | 06:15 PM
RLW
Send me your name and address via a PM. I might be able to help you out with a template which, I believe, has instructions printed on it.
Russ
RLW is offline
Old 02-18-2005 | 08:17 PM
Russ,
I sent you a PM.
Thanks,
Dail
Old 02-19-2005 | 06:38 AM
i have a extra template i can mail ya
open87 is offline
Iggy
5
08-06-2014 12:42 PM
Blue242
11
06-04-2008 01:41 PM
375stinger
12
12-13-2006 03:16 PM
FBRONCO
7
01-15-2003 12:04 PM
BruceK
05-17-2002 12:55 PM
