Removing paint from Gelcoat >
Old 02-23-2005 | 06:04 PM
Default Removing paint from Gelcoat
I am going to update the graphics on my Shadow cat.The boat is all white except for some painted stripng on the side that is already wearing off.What would be the best way to remove the striping.I was thinking of wet sanding the area.Any suggestions?
Mark
fishead is offline
Old 02-23-2005 | 06:08 PM
Default Re: Removing paint from Gelcoat
I've used "E-Z Off" oven cleaner-it works great! Spray it on, let it sit for a few minutes-use an abrasive sponge to wipe off, then rinse throughly. Make sure you wipe the E-Z off from the gelcoat while its working on the paint.
Fast Shafts is offline
Old 02-23-2005 | 07:00 PM
I was just going to make that suggestion! I saw the local Fountain dealer taking paint stripes off the hull with oven cleaner. Couldn't believe it, but it worked. He used to paint cars for a living and he did paint some graphics on Fountains, so I guess he knew what he was doing.
innthered is offline
Old 02-23-2005 | 07:56 PM
nauti-buoy's Avatar
wow i have never heard that one
nauti-buoy is offline
Old 02-23-2005 | 09:21 PM
Formula Outlaw's Avatar
Wish I'd known about that. Would have saved me a lot of work.
Formula Outlaw is offline
Old 02-24-2005 | 12:06 PM
Thanks, I had no idea.So you are telling me spray the paint with oven cleaners,let sit and scrub off.But be careful with the unpainted gel.
fishead is offline
Old 02-24-2005 | 03:02 PM
jayboat's Avatar
I've been using this process for about 20 years now to remove old graphics and lettering from boats (it's an old signpainter trick). Make sure you protect anything you dont want removed (such as bottom paint- not the unpainted gelcoat). I prefer a plastic pot scrubber to help break down the paint- an abrasive sponge could scratch your finish. Depending on type of paint and thickness it may take a couple of applications. Wipe the goo off with paper towels- dont rinse until you are finished removing the paint. Sometimes the cleaner will yellow the gelcoat- if this happens, put some bleach on a rag and wipe it over the affected area. Main thing is patience- give the cleaner time to do its thing...
Roostertail does not lie.
NAPLES IMAGE Photo Galleries
jayboat is offline
offthefront
Detailing, Painting, & Fiberglass
19
04-25-2006 08:34 AM
kcgbjc
04-17-2005 02:52 PM
marinetrans
03-27-2004 02:55 PM
Toffen
15
11-27-2002 04:18 PM
Toffen
11-21-2002 04:08 PM
