Gear Splitter >
Gear Splitter
Gear Splitter
Old 02-25-2005 | 09:51 AM
Lightbulb Gear Splitter
Just found an article from IMCO on a gear splitter.JUNE OF 2003.Forget the staggered Y2K.Picture this 598 cubic inches 750hp through a gear splitter to 2 bravo drives very close together like a stagger set up.So you only have 375hp to each drive. You know now 750hp doesn't seem like allot.
What are the rules in F1 does it say anything about 2 drives.It does say single engine and factory drive but what about 2 factory drives and a single engine.Everybody's interpretation of the rules is different.
z.zuperboat is offline
Old 02-25-2005 | 07:03 PM
tripps's Avatar
Default Re: Gear Splitter
the cruiseship has a gearsplitter,and it splits CORONAS and it dont have bravo's!!!! tripps
tripps is offline
Old 02-26-2005 | 05:48 AM
Superbabi's Avatar
Zz, I'm Not Sure What Advantage One Would Gain With 2 Drives On One Driveshaft/motor ??? Wouldn't You End Up With More Drag With Extra Drive And A Hp Loss With Gear Splitter ????
Superbabi is offline
Old 02-26-2005 | 08:27 AM
the boat they tried it on had a paul paff twin turbo ran 120 making 1500hp and runnung a #5 drive,then switched to the splitter and bravos and only needed 1100hp to go 120mph.Turbos have adjustable waste gates and they knew from dyno testing how much boost made how much power.How it would it work with stock power who knows?
YOOOO TRIPPS the big V is still at the house and hows the zupercruise going.
Old 02-26-2005 | 10:01 AM
tripps's Avatar
hey zup,eric jr says hi from the carribean,and did it matter if r picked the v up? i got a coupla weeks left,ill get it goin tripps
tripps is offline
Old 02-26-2005 | 11:44 AM
Pat McPherson's Avatar
I think I read about that gear splitter thing. It was done on a relatively some boat if I remember correctly.
It would help boat handling around the docks and give neck snapping acceleration...
Hey tripps,
Is there something you're not telling us?
What's up with your 30' V?
Patrick
Pat McPherson is offline
Old 02-26-2005 | 01:46 PM
Im sure that having another prop pushing will out weigh the drag of another gear case.They did say that acceleration was like an 11 second street car.I miss that fealing.Nothing like a set of hot slicks with about 8 pounds of air and a 4500 converter with a trans brake!Better in turns with 1 prop always hooked up.If it would work like a duoprop did on my buddies cabin cruiser,he picked up 10 mph going from an alpha with a good stainless prop to the twin prop bravo3.
Old 02-27-2005 | 09:32 PM
FX10's Avatar
Whats the reliability of a big HP motor compared to staggared 496 HO's. It is a cool idea though. Can you say 1300 Sterling with gear drive ? Hmmmmmmmmm
FX10 is offline
Old 02-28-2005 | 07:55 PM
tripps's Avatar
Hi pat,hows things,yeah,the gear splitter still works,but i havent been using it that much latley,it works best in hot sunny days,usually on weekends,with fellow boaters ,and the only thing going on the 30V is another powerhead How is your ride doin?? are you getting ready for june 11th?? tripps
tripps is offline
Old 03-01-2005 | 07:46 AM
Hi tripps,
I'm picking up my 502 block from the machine shop today. Hopefully I'll get it built and in the boat buy May 1st. But if I run into a snag, the 454 that is in the boat was running when I put her away...
See You Soon!
Patrick
