Prop ?  Mirage vs. Laser II vs. Ballistic >
Old 02-28-2005 | 02:17 PM
Default Prop ? Mirage vs. Laser II vs. Ballistic
I have a 95 2102 VIP Victory with a 350 Mag MPI and the 1.47? Alpha. I am currently running a Ballistic 21p and running at about 4950 wot. The Rpm is fine, but I need some more bow lift. I have a friend that is going to let me try his 21p Mirage in a couple of weeks. I was also wondering about a Laser II. What RPM do you think I would be running with the Laser II? Would I theoretically need a 23P on the Laser II since it is a smaller wheel? Any ideas?
justinVIP is offline
Old 02-28-2005 | 02:37 PM
Default Re: Prop ? Mirage vs. Laser II vs. Ballistic
A Mirage Plus will give you the most bow lift.
Griff is offline
Old 02-28-2005 | 03:31 PM
throttleup's Avatar
I agree!
Julie
throttleup is offline
Old 02-28-2005 | 06:27 PM
anyone know about the laser? my Ballistic prop is a 14 3/8" wheel. What is the Mirage, Mirage plus, or the Laser II? I heard that the Laser II is a smaller diameter wheel, and I just figured that I could go up a size on that prop and keep the same RPM. Thanks, I'm not very familiar with props and their characteristics.
Old 02-28-2005 | 07:38 PM
What about the revolution 4? Would I have to go to a 19 or lower to make this work? I found a 19P for $300. What would the benefits etc. be? Thanks for your knowledge. J.
Old 02-28-2005 | 08:31 PM
Rev 4 gives a lot of stern lift. Not what you want for bow lift.
All Mirage Plus' I have seen have been between 14.5 and 14.75"
Try a 21" Mirage Plus. It most likely will be the fastest on top end.
A regular Mirage(older design) has less cupping than a Plus. It will turn about 200 rpms faster than a Plus at the same speed.
Griff is offline
onesickpantera
07-13-2005 01:40 PM
onesickpantera
Prop Talk
14
06-10-2005 08:39 PM
rsx_tech
4
03-14-2005 11:54 AM
BAD-HABIT
11
07-28-2002 11:44 PM
fountain27ho496
6
07-12-2002 09:50 AM
