changing bulkheads  repair >
Old 03-02-2005 | 10:46 AM
AIR TIME's Avatar
Default changing bulkheads repair
changing bulkheads found crack roten spot in bulkhead in front of motor with tinybit of frost boats inside a coverit garage ,do you thing water migth be in the foam under the floors ,should I remove gas tank too?the boats a 88 240 sport 647hp I WAS GOING TO SHAPE OUT A BULKHEAD FOR IN FRONT OF THE CABIN GETTING RID OF THE PLEXIE GLASS
AIR TIME is offline
Old 03-04-2005 | 10:37 AM
SSComp's Avatar
Default Re: changing bulkheads repair
Pics?
Do you have access panels infront of the back seat to see the other side of the bulkhead?
My bulkhead was also rotten. The bulkhead actually had two distictive parts.
One was structural (plywood) where the stingers tie into. The other is above it (balsa core) and is part of the floor.
SSComp is offline
Old 03-10-2005 | 05:28 PM
AIR TIME's Avatar
Sorry for not responding I didn't see any replys wright away I have a bulkhead that even with the floor and is cracked between the stringers what I'm going to do is cut out the roten partif its real bad I'M GOING TO START RIPPEN EVERYTHING UP WHEN i REPLACE THE BULKHEAD it will run straight up the sides to stiffen the boat I already have robs I added next to the bolster seats to stiffen the gunnels seats are new offshore performace S/S STANDS DROP OUT I'LL CHECK LATER IF YOU HAVE ANY Q/A LATER ART
AIR TIME is offline
Old 03-10-2005 | 06:08 PM
AIR TIME's Avatar
PS PICS I can take some over the weekend if the racoon moved out my two labs chased it last weekend in to my potable garage where the boat is I took a peak inside and I think it went out the back plus I have to learn how to post picks my wifes a programer so I 'LL HAVE TO BRIBE WITH SEX OR WASH HER SUV OR
AIR TIME is offline
Old 03-10-2005 | 09:25 PM
outlawinil's Avatar
Sounds like it's never a dull moment there!!
outlawinil is offline
Old 03-11-2005 | 10:56 PM
Codered's Avatar
I have a 89 240 Sport i"m in the process of doing a floor and stringer call me if you like,too much to discuss and I dont type verry fast Walt 410375 4809
Codered is offline
Old 03-13-2005 | 09:30 PM
AIR TIME's Avatar
HEY me to I'm a one finger typer walt I'LL GIVE YOU A CALL DURING THE WEEK BECAUSEITS 1030ETPM. DULL not hear boy do I have some stories ,well I put some moth balls in the boat just to make sure no 4 legged pals kicken around boy do I have a lot of work to do in 14weeks to make the cape race tomorrow I'LL post my top ten list
AIR TIME is offline
AIR TIME
Detailing, Painting, & Fiberglass
0
11-07-2006 08:46 PM
trader1
06-25-2004 10:39 AM
Cash Bar
Fountain
2
04-09-2003 11:19 AM
cdaddygreg@aol.
Fountain
3
05-22-2002 03:48 PM
