Audio Guys I need cable help
Getting everything together for the intercom. I am using a stereo aviation system (flightcom). I am changing the phono plugs that are used in aviation with Neutrix D-series & RC series connectors and plugs, gold plated naturally, on the headset side. On the back of the intercom unit is a standard 25 pin din connector. I need a decent 5 conductor sheilded cable (2 conductors for mic, 3 for audio) to run from the intercom box to all the headsets.
Any recommendations? Will probably need 150' of cable in total.
The cable is the only thing that is left to buy. So far I have just under $500 invested in a stereo intercom with audio input and 6 headsets.
I have what you need but not enough to do 150 feet.
It's "two pair" balanced audio install cable. You would have one extra conductor, but the cable is easy to find.
It would be two shielded twisted pairs each with a "drain" or ground lead that is not jacketed.
Wish I had 150 feet, I would give it to you.
Not sure if this post was clear.
6 total conductors.
Finding 5 conductor shielded wire will be tough unless the cable was designed for a shared ground lead.
No problem.
6 total conductors.
6 total conductors.
http://www.allkindscable.com/wespen360shi.html
Precisely, except mine is Capital brand, rather than West Penn.
But the same specs.
I think that the stuff that I have is even 18 gauge like your pic.
But the same specs.
Do I run 2 cables, one for audio and one for mic?
The Neutrik connector is a 5 pin connector.
Is this going to be wire that runs through the boat or does it have to be flexible as it is going up to the head sets? If going through the boat then I would say use Cat5. The way the twists are gives you a very good shield and it is actually very good at sending sound through as long at the power is fairly low as it will be going to head sets.
Other then that I am fairly sure that I have a box of cable that I keep wanting to toss but keep saying some one is going to need this some day...... I will be at my shop on Sunday and I can see if I still have it. I think it is twisted pairs but I am not 100% sure. I do know it is shielded. I think there are 6 wires plus a drain. If you do not find anything by then then give me a call on Sunday and I will take a look (978) 985-0639
Jon
Jon
Put your best foot forward!
