I need a hand with a sender on a Eliminator >
Old 03-15-2005 | 03:05 PM
hpy540's Avatar
Exclamation I need a hand with a sender on a Eliminator
I started putting my wiring harness on the 540 today with expectations of dropping it in this weekend. Yes i know i said i was going to drop it in last weekend but hey things got pushed back(my pushrods didn't show up). I now find out that i do not have a oil pressure sender on the old power. I called Eliminator to buy one and their parts guy is on vacation till next week some time. Can NE1 tell me what PN sender i should put on this thing. I would imagine it is a standard analog sender that i could pick up at NAPA or something. It is a 236 eagle and it had a 454 mag in it. The old power was froze broke and did not have a sender, just a hole where it was. I will check and post the pressure range a little later. I checked Bam and i cannot find a mec sender diagram. Eliminator has their own gages( WHO MAKES THEM? MAYBE GAFFRIG). If any one has any experience with eliminators or what sender i should use, let me know.
thanx
Mark
hpy540 is offline
Old 03-15-2005 | 03:28 PM
Default Re: I need a hand with a sender on a Eliminator
The guages could be Gaffrig or maybe Faria? Is it an 80 PSI guage? Just make sure the sender matches the guage. I once ran a 0-100 PSI guage with the standard 0-80 PSI sender and the pressure read way high. Check the Rex or CP website or give Fred a call at Trick Marine. Auto store senders might work, but I would feel more comfortable getting the exact one for oil pressure.
Craig
WETTE VETTE is offline
Old 03-15-2005 | 04:02 PM
lightspeed's Avatar
If You Have West Marine Around You They Would Have It Teleflex Makes them Just make Sure Sender matchs Gauge. 80 lb gauge 80 Sender
lightspeed is offline
Old 03-15-2005 | 05:34 PM
Hpy 540, I can't wait to hear the results. Greg
HPJunkie is offline
Old 03-15-2005 | 06:33 PM
hpy540's Avatar
Hey Greg, when i get this whole scenario finished i wouldn't mind a trip to the Rockford area. I have two properties i am developing this summer and a additional spec for a client but i hope i can play with my new toy a little. would ya care to show me around the northern IL lakes?
hpy540 is offline
Old 03-15-2005 | 06:40 PM
tomtbone1993's Avatar
check with TRICK MARINE, i ordered mine today
tomtbone1993 is offline
Old 03-16-2005 | 07:11 AM
Mark no problem. Maybe we can get a couple hot boats out at the same time? Ever been to Madison wis? Good spot. Mississippi river?http://www.fullmooninjune.info/pages/2/index.htm We are going on the 17,18,19 of June your welcome to go. Keep us posted on that rocket! Greg
HPJunkie is offline
Old 03-16-2005 | 10:22 AM
jdnca1's Avatar
Hardin Marine made the guages in my Eliminator.....most senders will work but must match the range on your guages. Another words, don't try to use a 0-100 psi sender for a 0-80psi guage.....
I switched all of my guages to livorsi last year and did not have to change any senders...BUT I matched the ranges to what I was taking out.
jdnca1 is offline
jhiguy377
09-27-2007 12:33 PM
Danny_Ocean
4
04-05-2004 10:47 PM
phastang
07-29-2003 06:49 PM
