Engine coupler replacment poll... >
View Poll Results: see post for question.
Yes, I replaced it with an new HD.
20
44.44%
Yes, I replaced it with an new standard one.
8
17.78%
No, It looked fine.
14
31.11%
No, I didnt even look at it.
0
0%
Coupler? What Couler???
3
6.67%
Voters: 45. You may not vote on this poll
Old 03-17-2005 | 11:46 AM
jadento's Avatar
Default Engine coupler replacment poll...
While you have your engine(s) out to replace or rebuild do you worry about replacing the coupler(s) between the flywheel and your outdrive?
jadento is offline
Old 03-17-2005 | 01:12 PM
KNOT-RIGHT's Avatar
Default Re: Engine coupler replacment poll...
HD all the way!
Cp performance has them also Marc at BAM.
Dual springs.
KNOT-RIGHT is offline
Old 03-17-2005 | 03:36 PM
nauti-buoy's Avatar
I would do it. It is not a good feeling for that to let go at 10 at night.
nauti-buoy is offline
Old 03-17-2005 | 08:56 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Only if it needs it.
Why replace a perfectly good coupler just for the sake of replacing it?
But if it does show questionable, then by all means. Standard for normal applications.
US1 Fountain is offline
Old 03-17-2005 | 11:07 PM
articfriends's Avatar
If you have one w/aluminum splines they should be replaced no matter what because they sometimes strip suddenly with no real warning,Smitty
articfriends is offline
Old 03-18-2005 | 07:38 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
jadento, do you still have your 27 Baja? Just curious.
If you have the opportunity to change the coupler out, I would go ahead and do so.
Sydwayz is offline
Old 03-18-2005 | 07:52 AM
OldSchool's Avatar
Been there... and although it did happen suddenly, I was running the piss out of it in some rough water the previous two hours of running time.
OldSchool is offline
Old 03-18-2005 | 07:56 AM
jadento's Avatar
Sydwayz,
Nope, I sold it. I miss having my own boat alot, but I get out pretty much whenever I want on friends boats. Kinda nice not having a payment and still getting to be out there.
jadento is offline
Old 03-18-2005 | 08:34 AM
Exclamation Re: Engine coupler replacment poll...
I did this last spring after I stripped one out, I replace both at the same time with the HD's and there is a huge diff. You won't go wrong getting the HD's!!!
kilroy is offline
Old 03-18-2005 | 09:14 AM
jadento's Avatar
I have heard the extra thickness/depth of the HD couplers spline makes engine to drive alignment even more crutial. I.E. if it isn't correct the splines wear worse or faster? Is this true?
jadento is offline
