Towing advantage with 8 foot bed >
Old 03-17-2005 | 04:13 PM
thunderdan's Avatar
Default Towing advantage with 8 foot bed
I am getting ready to look for a new truck. I have made up my mind that it is going to be another f-250 crew cab with the camper package and stabalizer package. I will be towing a new 37 Chief that will weigh around 12k pounds with trailer and gear. I towed a similar boat with the same truck with the 7.3 liter and 8ft bed without any problems.
I would prefer the 6 3/4 bed as it is also my daily driver. Is there any real twoing advantage as far as stability with the longer bed?
thunderdan is offline
Old 03-17-2005 | 04:16 PM
Sean H's Avatar
A to Z
Default Re: Towing advantage with 8 foot bed
the added wheelbase will give you stability but not that much.... a gooseneck trailer with 12k would be a cinch to tow...
Sean H is offline
Old 03-17-2005 | 05:09 PM
excursion's Avatar
No problem at all with the short bed, I used to pull the 37 with a Excursion 7.3, pulled great, just on the interstate if a semi flys by it will push the truck around a little, thats why I went to a dually. The new 6.0 is a much better motor than the 7.3. The trans in the tow/haul mode is great.
What power you going too put in the Chief?? Graphics????
James
excursion is offline
Old 03-18-2005 | 08:41 AM
Thunderdan:
This is interesting, in one thread they tell an OSO'er towing a 36 Nortech to get a dually. On this thread they telly you to go with the shorter bed. I would go with the longer bed with that much weight (12k).
Wannabe
wannabe is offline
Old 03-18-2005 | 09:20 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I think having the shortbed dually will overcome the shorter wheelbase as opposed to having the full length of a full length bed. I have had friends who have had both, and stated this is the case.
As far as Fords go, I would want this order in means of towing stability;
Assuming all crew cabs:
350 6 foot bed SRW
350 8 foot bed SRW
350 6 foot bed DRW
350 8 foot bed DRW
Dan, Docmanrich37 has a 2500HD Chevy, CC, Short-bed, pulling his 37AT on a Myco with Electric over Hydraulic Brakes. I think you will be fine with whatever you choose, but if I were buying a Ford, isn't the F350 only a few hundred more than the F250?
PM Troutly for more info. He has forgotten more about Ford trucks than most of us will ever know.
Sydwayz is offline
Old 03-18-2005 | 05:40 PM
thunderdan's Avatar
350 6 foot bed SRW
350 8 foot bed SRW
350 6 foot bed DRW
350 8 foot bed DRW
It is not a $ issue for me, it is availability. I am looking at all SRW trucks. I did find one with the suspension upgrades so it has that, plus I anted the better ride of the 250. My last truck was a crew cab with the 8ft bed and it was a pain in the ass to drive around. I only tow maybe 4-6 times a year, maybe once down to Fla and back(I usually have it hauled). I was going to go with the shorter bed to make it easier for my daily driver.
But I also do not want to have an issue towing..
Old 03-18-2005 | 06:22 PM
thunderdan's Avatar
The camper package is 1 upfront spring(400 lb upgrade), rear stabalizer bar, and aux rear springs,
Old 03-23-2005 | 08:06 PM
Madcow's Avatar
I pull a 42 Sonic on a heavy trailer (About 15000 total) with a 4 door short bed. No problems at all. Toledo to Miami and back.
Madcow is offline
dankerst
27
03-14-2006 08:49 PM
Clay Washington
Cigarette
14
08-30-2005 03:48 PM
Clay Washington
08-13-2003 08:41 AM
Clay Washington
07-17-2003 09:43 PM
