props
props
I have a 32 ft sutphen with 2 , 300 hp mercury engines that i am rigging as new. They sit on a stainless bracket. What size and type props would you recommend? The total weight should be 6200 lbs. I am looking for top speed.
Two-Air has a good point. You want to talk to a professional before you get started. But, once they get you started, the only way to get the exact prop for your ride is the try, try, and try again. Get the prop that's recommended, then change things a few times to tune it in perfectly.
If your looking for outboard props, I have a pair of Mercury Offshore Performance 4 blade props. 23" Pitch. Check the mercury description on them, they are designed for Outboard motors. They are in PERFECT condition. You can take them home for $450. Don't have a pic right now, but if you are interrested, let me know and I will get you a pic.
jerome lusa,
Welcome to the world of testing. In your case I have a pretty good Idea of were we need to be. But I am going to need to ask you alot of questions. Please feel free to call me.
Julie
Throttle Up Propellers
727-531-2255
Julie
727-531-2255
raiseyourdrive
09-15-2004 08:23 AM
