Blackhawk drives >
Blackhawk drives
Blackhawk drives
Old 03-20-2005 | 01:58 PM
Default Blackhawk drives
I was wondering if anyone has any reason I should not purchase a 1996 Scarab P-29 with the 350mag and Blackhawk drives. I really don't want to find out that they are troublesome. HELP.
speedchangesyou is offline
Old 03-20-2005 | 02:52 PM
hillbilly24's Avatar
Default Re: Blackhawk drives
There are no major reliability problems with them and on the right setup they run great. As of right now the parts or available for them but as with all dicontinued products that may change sometime in the future.
hillbilly24 is offline
Old 03-20-2005 | 08:04 PM
Was the boat originally set-up with the blackhawks?
What ratio?
What props?
How many hours on the blackhawks?
What are the s/n's?
indyblackhawk is offline
Old 03-21-2005 | 07:19 AM
Official OSO boat whore
P-29's were setup from the factory for the BH. If you are ham fisted with the throttle you'll bust them up. If you baby the throttles when it matters, they will live. Be sure to test drive the boat because the do have some quirks that will take some getting used to.
Is this boat red and yellow?
Cord is offline
Old 03-21-2005 | 07:40 AM
Mbam's Avatar
Offshoreonly Advertiser
I doubt if you will hurt them with the small blocks, but depending on the year an updating to the new style upper gears would not hurt.
Mbam is offline
Old 03-21-2005 | 10:54 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
P-29 only came with Red/Yellow, 350 Mags and the BH drives. Shoot a PM to "Lapse of Reason" here on OSO. He had one for a few season, and I almost bought it from the dealer where he traded it. I ended up buying a 26' Sonic, as I thought it had more to offer. I was very satisfied with my choice.
Sydwayz is offline
Old 03-29-2005 | 08:06 PM
Raced a p-29 and his holeshot was outstanding...good luck thats all I know...
rfoxx987 is offline
Old 04-01-2005 | 12:24 PM
tssteph's Avatar
Are Blackhawks a direct replacement for a Bravo drives? Will all the same hyd steering components work on them.
I am told that on a 29 Scarab the BH drives are faster.... I have Bravo's
tssteph is offline
Old 04-01-2005 | 06:14 PM
They are a good 10mph faster. They bolt right on to the bravo gimble, but you need to watch your x-dim. The blackhawk is some 7" shorter! No, the hydraulic steering won't bolt up. You will need to custom fabricate a steering bracket. There were 3 different version of the blackhawk back cap made. A wing plate that fits one bh won't necessarily fit another. Imco still offers a wing plate for the BH. It's like $700 and isn't compatable with their other steering systems. Plan on custom making the plate. It'll be much less of a headache.
Cord is offline
Ricochet
Drives and Lower Units
38
01-09-2018 10:34 AM
TexomaPowerboater
Sonic
10
06-16-2007 05:57 AM
p29steve
07-28-2005 05:19 PM
mhunter
07-14-2002 12:35 PM
283CHECK
02-28-2002 12:25 PM
