Electrical guru's >
Electrical guru's
Electrical guru's
Old 03-20-2005 | 04:52 PM
PorscheSpeed's Avatar
Default Electrical guru's
I need a way to use 12 volt electronics i.e: phone chargers. sound systems, and the usual..
How cam I go from 24 to 12 volt? do they make in inverter to do this?
PorscheSpeed is offline
Old 03-20-2005 | 05:04 PM
blkhorse's Avatar
Default Re: Electrical guru's
how many battery's do you have? if there 2, 12 volt just tapp off one battery
blkhorse is offline
Old 03-20-2005 | 05:09 PM
Cool Trips's Avatar
Alot of larger diesel powered boats use 24 volt starters on the engines but split the system to power 12 volt things. They use 12 volt batteries but wire them together to get the 24 volts. Some big trucks have the same set up.
Cool Trips is offline
Old 03-20-2005 | 05:10 PM
2
wont that drain 1 battery faster then the other one?
Old 03-20-2005 | 05:11 PM
This is a Military vheicle. so EVERYTHING in the truck is 24V
Old 03-20-2005 | 05:18 PM
KNOT-RIGHT's Avatar
DC to DC inverters.http://www.powerstream.com/dc12-48.htm
scroll down and click on consumer style converters
then click 24 to 12
This may work. depending on load.
Gerry
KNOT-RIGHT is offline
Cool Trips's Avatar
Unless the vehicle has a 24 volt battery you can split off one of the 12 volts to get your supply. If it has a 24 volt battery you will need a transformer not an inverter.
Old 03-20-2005 | 05:21 PM
KNOT-RIGHT's Avatar
Actually a transformer will not work for dc
Old 03-20-2005 | 05:25 PM
KNOT-RIGHT's Avatar
Simply put What a inverter does in this case is converts the dc to ac then runs through a step down transformer then converts it back to dc.
Its easy to go to ac to dc. Going from DC to AC is the trick.
Can you say Oscillator. It actually switches the polarity of the dc many times. (60 hz). However viewed with a scope will reveal a square sign wave.
I know Im a Geek
Gerry
Old 03-20-2005 | 05:29 PM
KNOT-RIGHT's Avatar
Porsche check this outhttp://mightymo.org/Proj_24vFrom12V.html
Go the other way
