Temp range for 3M 5200 >
Old 03-21-2005 | 12:32 PM
Default Temp range for 3M 5200
I need to bond 2 aluminum plates. One will be subjected to engine coolant heat, up to 190 degrees. Does 5200 work well at high temps?
Gary
Gary Anderson is offline
Old 03-21-2005 | 02:28 PM
Chris288's Avatar
Default Re: Temp range for 3M 5200
3M 5200 Spec. Sheet..
http://multimedia.mmm.com/mws/mediaw...000Qu_lWD9Ga4-
looks to me like its good to EXACTLY 190 degrees..
Chris288 is offline
Old 03-21-2005 | 06:50 PM
ratman's Avatar
try jb weld it will handle a LOT of heat. the original slow cure is the best... good luck wif it
ratman is offline
Old 03-22-2005 | 09:54 AM
The 190 temp range is a little too close for comfort. Looks like I'll try the JB weld instead. Thanks.
Gary
Old 03-22-2005 | 08:40 PM
mcollinstn's Avatar
I've got some heat activated single part epoxy. It's past its expiration date, so I'll send you a tube for postage if you'd like. I've kept it in a freezer the whole time, so it's probably still good.
THIS STUFF WILL BOND LIKE MAD. Requires being cooked at 425 degrees for about 15 minutes to set.
We made robot arms for a transfer press system, and bonded aluminum angle brackets to magnesium support arms. Within 2 years, they had destroyed all 15 sets of these things by crashing them in their presses (they never would finish programming the failsafe sensors into the controller...). I mean they mangled these things into pure junk. But the adhesive only failed at one spot on one arm, where the entire bonded area was smashed to about half thickness, squirting aluminum and shattering the more brittle magnesium. Adhesive failed on that spot.
This stuff is only available in tubes to fit in a caulk gun sort of applicator (which I will lend you if you send it back).
The only worry is that the epoxy being old will have an effect. It had a 1 year shelf life un-refrigerated. I've had it in the freezer for about 6 years.
All you got to lose is postage. You can try it on a small part first.
lemme know,.
mcollinstn is offline
Old 03-23-2005 | 09:19 AM
Thanks for the offer mcollinstn. I'll probably just go with JB weld since the bonding is really not structural.
But I would have paid to see those robots self destucting.
Old 03-23-2005 | 07:04 PM
ratman's Avatar
ditto
ratman is offline
Old 03-23-2005 | 07:17 PM
PHD, is this epoxy available somewhere? I may have a use for some down the road. Sounds like a good thing to have in the toolbox.
BadDog is offline
David Stotz
Do It Yourself, Boating on a Budget
13
03-19-2008 07:17 PM
rv
11-17-2005 06:29 PM
Here's Johnny
5
08-25-2005 11:03 AM
39 Unlimited
7
07-10-2005 07:33 PM
