low temps with crossovers >
Old 03-25-2005 | 01:09 PM
Angry low temps with crossovers
I am having the same problems with low operating temps on my 454's. Just changed thermastats to 160. Engine's run around 100 degrees and I know thats way too cool. The therm. housing has this spring and plastic 3 fin diverter inside. Don,t know much about this type of setup. How can I get the temps up without buying new recirulating pumps and all the harware? I do not have a bypass and do not seem to have pressure problems.
team Tickfaw is offline
Old 03-25-2005 | 02:27 PM
GPM
Default Re: low temps with crossovers
Is there any water flow thru that engine when the thermostat is closed?
GPM is offline
Old 03-28-2005 | 09:17 PM
Question Re: low temps with crossovers
Been out on the river all weekend and boat running good. It seems to be putting water through engine . You can feel water going through the small hoses at therm housing. Ran boat at 4000 rpm for 30 min. crossing lake and the highest temp got was 105.
Old 03-28-2005 | 09:49 PM
Hot Boat's Avatar
Team Dysfunctional
What cross over and motor do you have???
If it aint broke .... I can break it....
Hot Boat is offline
Old 03-28-2005 | 10:06 PM
RedDog382's Avatar
Are your exhaust manifolds even getting warm?
Maybe something stuck in the thermostat keeping it open? I had the small cork gasket that goes on top of the thermostat slip out of place on reassembly and cause a similar problem, but to a lesser degree. It just took longer to warm up than my other motor.
Maybe a defective temp sending unit?
RedDog382 is offline
Old 03-28-2005 | 10:34 PM
Cool Re: low temps with crossovers
Don't know what kind of x-over. The exhaust manifolds are getting warm but certainly not too hot you cannot leave your hand resting on it. I have changed both temp sending units. When at house on the muffs, running 1000 rpm I checked exhaust water temp and it was around 105 degrees.
Old 03-28-2005 | 10:38 PM
Red face Re: low temps with crossovers
forgot, the engines are 1989 mark 4 454's built with larger cam, crane roller rockers, gil headers, weiand single plane, 850 double pumpers. Boat is a 1991 30' Baja Sport.
Old 03-29-2005 | 02:38 AM
Strip Poker 388's Avatar
Rob
Thermostat stuck open?
Strip Poker 388 is offline
Old 03-29-2005 | 09:45 AM
Both brand new from C P performance.
shaun harrington
Wanted
10
06-19-2008 10:41 PM
offthefront
20
01-01-2008 12:54 PM
Mr Gadgets
58
12-21-2007 11:54 AM
BadDog
2
05-15-2007 01:44 AM
sre
4
05-03-2007 12:43 PM
