SSM 2's or 3's >
SSM 2's or 3's
SSM 2's or 3's
Old 03-25-2005 | 07:46 PM
Dtile's Avatar
Default SSM 2's or 3's
Can anyone tell me what drives these are or how can I tell the differnce from a 2 & 3.
http://www.ldeo.columbia.edu/~mvitel...in/1259849.jpg
or
http://www.ldeo.columbia.edu/~mvitel...n/PCDV0038.JPG
mike
Dtile is offline
Old 03-25-2005 | 09:28 PM
tcelano's Avatar
Default Re: SSM 2's or 3's
These definitely look like SSM II's based on the size of the upper housing, and the fact that a small diameter prop fills it up to the cav plate. Also, the trim rams are way too small in diameter to be III's
To be sure, check the serial numbers:
SSM II older than 1985:
serial numbers up to Z2021212C where the first letter indicates the gear ratio
or after 1985:
serial numbers A 544504Z using the last letter as the gear ratio.
SSM III's:
Z38022378C through X38092085C where the first letter is gear ratio
or
A568120Z where the last letter is the gear ratio.
tcelano is offline
Old 03-25-2005 | 09:32 PM
Dtile's Avatar
tcelano, thanks...just checking.
Dtile is offline
Old 03-25-2005 | 09:34 PM
Lofty's Avatar
Those are #2's. They are essentially TRS uppers with twin shaft speedie lowers. #3's look very similar but are a completely different drive.
Lofty is offline
Old 03-25-2005 | 09:36 PM
Lofty's Avatar
geez... I guess I took too long to post that one.
Lofty is offline
Old 03-26-2005 | 07:07 AM
Biggus's Avatar
Dtile,
Do you know if your boat was originally rigged with TRS drives?
Kurt
Biggus is offline
Old 03-26-2005 | 07:11 AM
Dtile's Avatar
I beleive so...ill check the serials today, before auction end.
http://cgi.ebay.com/ebaymotors/ws/eB...ADME:B:EF:US:1
Dtile is offline
Panther
Swap Shop
32
02-13-2009 01:25 PM
Mad Mac
5
01-30-2007 02:24 AM
bshzba
12-19-2005 04:20 PM
BLOWN 1100
10
12-16-2002 09:41 PM
