new 496 mag in older boat  tach issues >
Old 03-28-2005 | 06:16 AM
Default new 496 mag in older boat tach issues
just installed a new 496 mag in my 89 formula i just plugged in the harness and started but i have no tach my guess is the signal is wrong for the tach vdo i had this same prob w my 357 when i put msd ignition in i needed tach adapters but this system is 8 coils no dist anybody got any ideas
smokin' gun is offline
Old 03-28-2005 | 11:11 AM
Default Re: new 496 mag in older boat tach issues
I Would Guess Your Tach Is Analog And Your Motor Is Outputting Digital.
I Put 496's In My '89 Scarab, But The Only Gauges That No Longer Worked Were The Oil Temp.
89scarab3 is offline
Old 03-28-2005 | 02:59 PM
Dave M's Avatar
Veteran: Navy
I went from a '97 454 Mag MPI to a 496 HO, no problems. I guess your old engine was a carb? I think MPI/EFI and carb engines have a different harness.
Dave M is offline
Old 03-28-2005 | 09:34 PM
Pat McPherson's Avatar
I would compare a schematic of the old engine harness against the new.
I bet the tach wire is on a different pin.
Or you have a broken wire.
Bad grounding or a bad ignition switch can screw with your tach as well...
Patrick
Pat McPherson is offline
Old 03-28-2005 | 11:05 PM
Lofty's Avatar
What ignition are you running? What ignition was on your old motor? My guess is that you have the Merk Racing tachs? These ONLY work on the old style T-Bolt ignition, it's an outboard set up.
Lofty is offline
Niclas Tell
0
05-22-2008 04:09 AM
TeamPSI
23
12-10-2007 05:23 PM
boatme
08-14-2007 05:20 PM
STRAIGHTPRIORITY
02-02-2006 07:30 PM
smokin' gun
03-26-2005 08:37 AM
