I.T.S. and a stock Bravo 1 What has to be changed >
Old 03-28-2005 | 12:17 PM
magnum27's Avatar
Default I.T.S. and a stock Bravo 1 What has to be changed
I have an I.T.S. transom assembly that I am about to install on my boat and was wondering what parts will have to be changed on the drive in order for it to be mounted. It is a slandered Bravo 1. I know of coarse that I need a longer shaft as the I.T.S. has a seven inch set back, but who can sell me a shaft for a standard bravo to fit it. Also will anything else need changing?
magnum27 is offline
Old 03-28-2005 | 01:12 PM
Mbam's Avatar
Offshoreonly Advertiser
Default Re: I.T.S. and a stock Bravo 1 What has to be changed
The shaft might be a problem, as the one Merc makes is for an XR
Mbam is offline
Old 03-28-2005 | 02:19 PM
magnum27's Avatar
does anyone know someone who could make a shaft that would work? Or be able to take the shaft from an XR and weld on the end for a standard Bravo so it could work
magnum27 is offline
Old 03-28-2005 | 06:03 PM
Mr Gadgets's Avatar
Charter Member #601
magnum27,
I think you meant to spell standard Bravo 1? If so, You could get a set of XZ gears, I dont think the pinion is sold seperately, and you would need the clutch, universal joint assy, shift fork and all the bearings. In other words a total upgrade kit, but using the XZ gears. That would give you the stronger gears, but then you dont have a steel tower. Sounds like the easiest way is an XZ upper, then you need the gimble bearing kit. I have done some mixing and matching to accomodate things like this. Shoot me an email if you have more ???? or want some info on it..
Hope this helps.
Dick
Mr Gadgets is offline
Old 03-28-2005 | 06:45 PM
plumbers crack's Avatar
Talking Re: I.T.S. and a stock Bravo 1 What has to be changed
Just had my drive re done with the longer shaft for ITS.You need to order a new bearing,spanner nut and carrier from IMCO about $250.00 the shaft is about $850.00 It is only sold complete with gear and universals MRD charged $250.00 to assemble for me.The shaft is an XR.Good Luck
plumbers crack is offline
Old 03-29-2005 | 08:23 AM
magnum27's Avatar
That's what I needed to know, doesn't sound to bad, thanks for the info
magnum27 is offline
Frequency
Wanted
0
06-25-2008 08:15 PM
HotCig35
16
02-25-2007 07:18 PM
Buddy OO
Black Thunder
15
02-05-2007 09:52 PM
Pismo10
5
03-26-2005 03:21 PM
