Replacing to new Clarion everything!! >
Old 03-28-2005 | 02:53 PM
FunHome's Avatar
Default Replacing to new Clarion everything!!
Well I finally found out that we aren't getting hit as hard as I thought on Taxes this year, so I've got the go ahead on the stereo!!!
I decided to replace the old Clarion Stereo, Amp, CD Changer with newer versions of Clarion. I'm hoping that I can use alot of the same wiring!?!? I'm also replacing the VCR with a Dvd/Vcr combo and the old tube style TV to a LCD Flat Screen.
Where is the BEST/Cheapest place to buy Clarion Stereo equipment?? I want the CMD4 Stereo, two CMRC1 remotes, the 6 disk changer, I think the smaller 160w amp.
Anyone have anything good or bad to say about Clarion???
FunHome is offline
Old 03-28-2005 | 03:28 PM
Dock Holiday's Avatar
Charter Member #34
Default Re: Replacing to new Clarion everything!!
I really like Clarion.
They have served me very well, look good and they make a good product for the marine environment.
No problem at all with the head unit, remotes and CD changer. But I would probably buy a different brand speaker.
That is the way it is suppose to be.
You keep your money, you spend it, the economy keeps growning and everyone is happy!
Good Luck.
Dock Holiday is offline
Old 03-28-2005 | 03:38 PM
Steel Outlawed's Avatar
I'm a Clarion fan also. The CMD series of head units are great.
As far as the TV/DVD goes you might want to check into RCA's LCD TV that has the DVD built in. That is what I put into the 33.
Attached Thumbnails Replacing to new Clarion everything!!-465-6527_img-medium-.jpg
Steel Outlawed is offline
Old 03-28-2005 | 04:30 PM
Cmoney's Avatar
Have you ran your boat with the TV installed yet? I am asking because I would like to install one in my boat, but I am worried that a couple of big slams might break it off the wall.
Cmoney is offline
Old 03-28-2005 | 04:35 PM
Charter Member #34
I have had a Sharp 15 Inch flatscreen in by 36 for three seasons now and it does NOT move and still works great!
I mounted mine in the same place that jeff did. You must use a good quality bracket and put a strong backing plate on it for strength.
They are the only way to go!
As a matter of fact we were in Jeff's both heading out the inlet to Charleston last Saturday and his did great also! Some pretty good size rollers coming in!
Old 03-28-2005 | 09:14 PM
FunHome's Avatar
Questions to those with LCD TV's.......
Do the ones you have run off of 12 volt??
If so where did you get them??
The ones marketed to into cars are twice as much as the ones marketed to use in your home..........
A buddy said that he just bought a 13in. Sharp and said it is made for home use but was 12 volt that came with and adpator to change the ac to dc????? I'm confused??
BTW, how much power do the LCD's take???
FunHome is offline
Old 03-29-2005 | 07:06 AM
Charter Member #34
Same exact TV you buy at Best Buys for home use. Actually I purchased mine at Best Buys.
They work off 110 AC and 12 Volt DC. We have ours set up for 12 volt so we can use it away from shore power.
It does not draw a whole lot of power. At least I have never run the battery dead anyway!
They are hard to beat.
Old 03-29-2005 | 07:13 AM
Same with the RCA both 12 Volt and 110. I have mine hooked up to 12 volt also. Like Doc said you don't have to be hooked up to shore power to watch it.
Old 03-29-2005 | 12:42 PM
FunHome's Avatar
Cool!!! Thanks guys!! That is just what I've been wanting to find out!!!
I want to be able to run it without shorepower also!!!
FunHome is offline
Old 03-30-2005 | 12:10 PM
FASTTIMES's Avatar
If you interesting in selling the old clarion head unit let me know..
Travis
FASTTIMES is offline
