Can 280 K plane be straightened? >
Old 03-29-2005 | 01:09 PM
outlawinil's Avatar
Default Can 280 K plane be straightened?
I have a port side 280 K plane that is not perfectly flat. I parting out a wrecked boat and looks like this tab may have took a hit and bent it ever so slightly. I may notice a slight bend in the tab cylinder. Can these be purchased separately or fixed?
outlawinil is offline
Old 03-29-2005 | 01:48 PM
pachangalpina's Avatar
Default Re: Can 280 K plane be straightened?
Fred @ Trick Marine can get replacement cylinders that will work in place of the factory units at a huge savings.
pachangalpina is offline
Old 03-29-2005 | 01:54 PM
zt260's Avatar
You can buy the parts separately, but they cost big $$$$
I would look for used parts or this will cost you too much to salvage. I wouldn't be surprised if one new plate was $500 I can't guess at the cylinder.
zt260 is offline
Old 03-30-2005 | 01:28 AM
Strip Poker 388's Avatar
Rob
In a month I will be selling mine , I am going to 380's
Strip Poker 388 is offline
Old 03-30-2005 | 11:13 AM
Canada Jeff's Avatar
Take the cylinder off and go to a hydraulic shop. If its just the rod thats bent, they can replace and repack! I had a local shop replace the packings on one of mine last summer. Cheap!
Canada Jeff is offline
Old 03-31-2005 | 09:49 PM
outlawinil's Avatar
Hey Strip Poker...call me when you do...217-242-2561 or email me at [email protected]
Old 03-31-2005 | 10:05 PM
outlawinil's Avatar
Sure am...especially the port side
Old 03-31-2005 | 10:11 PM
outlawinil's Avatar
cool...that would be great
Old 04-01-2005 | 07:07 AM
martiniboat's Avatar
From: Brussels, Ont. CAN. Landlocked between Lake Huron, Ontario and Erie
That must've been a 'slight' bend. Usually, a cast aluminum tab (or virtually anything cast aluminum) has a small window read: tolerance to deflection, and just snaps.
It's great that you've found other options for the plates and Fred could definitely set you up with a pair of nice stainless cyls. They are much nicer looking than the stock issue in my opinion
martiniboat is offline
Old 04-14-2005 | 08:28 AM
outlawinil's Avatar
Hey Sutphen30...I got your plates...need to send check. I want to verify name and address. Email it to me at [email protected]
