exhaust port corrosion fix >
Old 03-31-2005 | 10:41 PM
ratman's Avatar
Default exhaust port corrosion fix
one of the exhaust ports on one of my heads has some severe pitting in the flat outer face where the exhaust gasket mates up. will some jb weld be o.k. to fill in the pitted area? do you think it will hold up or is there a better product for this? thx for any info, ratman
ratman is offline
Old 04-01-2005 | 09:23 AM
88Fount33's Avatar
Beak botr
Default Re: exhaust port corrosion fix
Don't know the temp limit of JB weld, but it is hot as Xxxx at this point. The gasket keeps heat tranfer between the manifold and head to a minimum. I would think you might have better luck with ultra high temp RTV exhaust gasket goog along with a new exhaust gasket. But then, don't know the temp limits of JB Weld before it "burns".
88Fount33 is offline
Old 04-01-2005 | 09:44 AM
rmbuilder's Avatar
MarineKinetics
Ratman,
If you are using this on the flange these should work.
http://www.aremco.com/a15.html
http://www.mcmaster.com/nav/enter.as...pe=&catnum=111
Bob
rmbuilder is offline
Old 04-02-2005 | 10:59 AM
ratman's Avatar
the header let go and 2 ports were pretty bad. i had em welded up and the machine shop is gonna remachine the mating surface. i figured now was the time to do it right as the motors are apart and im gonna dyno them next week
ratman is offline
375stinger
8
01-25-2006 04:12 PM
dukenrock
4
07-12-2005 12:49 PM
Zanie
4
05-10-2005 12:33 AM
Tinkerer
11-09-2002 06:50 PM
scarabrick
11-06-2002 03:11 PM
