what syn. gear lube for a ssm#3'a drive? >
Old 03-31-2005 | 10:43 PM
ratman's Avatar
Question what syn. gear lube for a ssm#3'a drive?
what snythetic gear oil should i run in a ssm#3'a drive? does it have i high pressure shock absorbtion additive? thx, for any info, ratman
ratman is offline
Old 04-02-2005 | 11:02 AM
ratman's Avatar
Default Re: what syn. gear lube for a ssm#3'a drive?
anybody? bam, wanna chime in here?
ratman is offline
Old 04-02-2005 | 11:27 AM
Mbam's Avatar
Offshoreonly Advertiser
All i've ever used is good old Mercury Hi-perf gear lube. I usually add Dow corning gear guard. It's a moly extreme pressure additive.
Mbam is offline
Old 04-02-2005 | 12:49 PM
BURNSMAZZ's Avatar
My buddy uses Mobil synthetic in his #3's he claims it's the next best thing to sliced bread.
BURNSMAZZ is offline
Old 04-02-2005 | 12:59 PM
Hydrocruiser's Avatar
HP or any Syntheitc should be fine.
Hydrocruiser is offline
Old 04-02-2005 | 01:01 PM
Arrow Re: what syn. gear lube for a ssm#3'a drive?
Mobil-1 is a good choice I have used it. It is a PAO fully synthetic lube with a great balanced GL-5+ additive package.
Old 04-03-2005 | 08:13 AM
SCRAPMAN1's Avatar
We Used Some New Stuff From Torco In A Set Of #5s With Good Results. I Had To Order It Through Torcos Distributor In Florida. His Name Is Jeff And His # Is 321-269-1498. Its Worth The Effort To Order, We Gained Speed!
SCRAPMAN1 is offline
Old 04-03-2005 | 09:42 AM
Crazyhorse's Avatar
I asked Mel Riggs that same question when he rebuilt a 3A for me and he said to use the Merc HP gear lube. So I do.
Crazyhorse is offline
Old 04-03-2005 | 06:06 PM
I talked to Joe at my local marina and he sees speed when going Torco in the bigger drive as well.
Hydrocruiser
7
05-31-2008 02:02 PM
Griswald
Drives and Lower Units
3
12-08-2007 03:20 PM
Rocko C
Baja
4
05-22-2006 02:06 PM
ratman
3
04-01-2005 06:45 AM
gripit
03-15-2005 11:22 AM
