Where is your ignition grounded? >
Old 04-01-2005 | 06:45 AM
OldSchool's Avatar
Default Where is your ignition grounded?
Question for you techies. My ignition (MSD) ground is on a ring terminal that is grounded on the back of the head. The head is aluminum. It seems to work fine but I'm wondering where everyone has their's grounded to? Should it be grounded to the block? Just wondering.....
Thanks in advance
OldSchool is offline
Old 04-01-2005 | 06:59 AM
martiniboat's Avatar
From: Brussels, Ont. CAN. Landlocked between Lake Huron, Ontario and Erie
Default Re: Where is your ignition grounded?
Yep, that's where my MSD is mounted to as well...
martiniboat is offline
Old 04-01-2005 | 07:18 AM
Ted G's Avatar
Should not make any real difference since aluminum is a fine conductor. You are also less prone to corrosion with aluminum. It is not a bad idea to pull and clean all the connectors and the grounds once a year (another thing for my damn list) since this has been thought to cause failures in the MSD systems.
www.cbpba.com
Ted G is offline
Old 04-01-2005 | 08:41 AM
OldSchool's Avatar
Thanks Guys!!!
nick9671
Fountain
5
06-17-2008 11:39 PM
grapeape93
05-25-2008 05:42 PM
27daytona
7
08-21-2007 11:22 PM
Luxy60
4
09-12-2002 03:13 AM
steve
13
06-11-2002 08:12 PM
