FASTEST Pleasure Skater?? >
Old 12-16-2005 | 01:49 PM
  #31
Default Re: FASTEST Pleasure Skater??
Whatever happened to KingSting? Wasnt it for sale?
Thats faster than Id ever want to go in a 32... I was over 170 in the new MyWay and you felt it at that speed in that big 46.. in a 32....
30Spectre is offline
Old 12-16-2005 | 02:15 PM
  #32
Sean H's Avatar
A to Z
did they ever add a windscreen to king sting? i bet that thing is no fun over 150 without wind protection....
Sean H is offline
Old 12-16-2005 | 02:57 PM
  #33
TeamSaris's Avatar
Driver-441
Racer
No and it is on Lake George. He mostly uses it as a lake boat. He has 8 mufflers on it so it passes.
TeamSaris is offline
Old 12-19-2005 | 08:22 PM
  #34
Jigsaw89's Avatar
What is in the yellow casing off the stern of Jet Set in post 23? A 'little' motor used to navigate docks and such would make sense, but it doesn't look like a motor to me. Anyone know for sure?
Thanks,
Dan
Jigsaw89 is offline
Old 12-19-2005 | 08:36 PM
  #35
Sean H's Avatar
A to Z
Thanks,
Dan
outboard to get around the docks...
Sean H is offline
Old 12-19-2005 | 09:47 PM
  #36
Sean is correct , it is a 60hp yahama ob with a jet pump. The turbines do not shift, start and go.
mmwalters is offline
Old 12-30-2005 | 02:16 PM
  #37
Tantrum's Avatar
6 inches is a bit of an exageration but not by much. I live less than 5 miles from where this pic is taken. Where Superbabi's boat is is at the edge of the chanel which is about 7-9ft max. If you jumped off the front of his boat you could walk (literally) to the far end of the bridge (Toms River Bridge)with only two small channels in between. Barneget Bay is very shallow but the bottom is very soft for the most part. We used to make our gas money here as kids pulling boats out of these shallows with our boston whalers. Jet Set also chooses to run there because nobody else does.
Tantrum is offline
Old 01-01-2006 | 06:27 PM
  #38
Jigsaw89's Avatar
Good point, Tantrum. My shore house is located in Toms River on the other side of the bridge so I too am quite familiar with the waters. There have been many times when I was out toolin' around on my SeaDoo (off shore directly across from Superbabi in pic above to the island house) and JetSet has blasted past me at 100++ mph in 12" to 18" of water. Cool boat and even more impressive when you see it in action!!
Happy New Year Everyone!!
Dan
Jigsaw89 is offline
Old 03-15-2006 | 09:03 PM
  #39
dank368's Avatar
So, just to recap.....which pleasure Skater is the fastest???
dank368 is offline
Old 03-15-2006 | 10:46 PM
  #40
blaniac's Avatar
That turbine boat is bad ass, but for non-turbine power, I vote for Kroozin !!!
blaniac is offline
