What's the story on this one? >
Old 01-04-2007 | 08:56 AM
TopSpin80's Avatar
Default What's the story on this one?
1989 Skater / Douglas Marine Offshore Racing, 32' A classic Skater currently set up for racing but could be retro-fitted for pleasure. Ran 130's with 850 engines.
Being sold without engines as they were recently sold.
Comes with triple axle aluminum trailer.
Equipped with fresh #5 drives built with all the correct HD 1.61 gears/etc.
Is a 1.61 gear ratio an overdrive or underdrive?
This boat was probably ran really hard and I know that, but what do you guys think it is worth?
I'm looking for a diesel project and this may be the one if I am ready in a few months.
Ernie
TopSpin80 is offline
Old 01-04-2007 | 08:57 AM
TopSpin80's Avatar
Default Re: What's the story on this one?
pics were not showing
the cover looks to come off and have some extra seating
Attached Thumbnails What's the story on this one?-86199086_1.jpg   What's the story on this one?-86199086_2.jpg   What's the story on this one?-86199086_4.jpg
Old 01-04-2007 | 11:21 AM
There is one on ebay right now with arnesons, its the new 32b.
Im also interested in doing a diesel app, let me know how it goes. We are neighbors.
Curtis
yahoo is offline
Old 01-04-2007 | 11:48 AM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Depending..... Upon the diesel you want to use, the 32A does not have sufficent bottom surface area to support the displacement of a heavy diesel. 1500 lbs ea. so to speak.
Now, a duramax 850 lb engine would be fine, but not a Yanmar.
The 32' B has a larger sponson and can carry the weight better than the 32' A. For a diesel look for a larger boat like the 36' Skater or small engines.
Rik is offline
Old 01-04-2007 | 12:23 PM
Not sure why you say that, there is only 210 lbs diff between a merc 525, and a yanmar 480hp.
Add a multispeed tranny to use all the torque.
CM
yahoo is offline
Old 01-04-2007 | 12:54 PM
TopSpin80's Avatar
cummins 5.9 with twin turbos....cnc ported heads
750hp
2200-2500 ftlsb torque
but redlines at less than 3k rpm
I'm looking into the heads and waterjacked exhaust... may have to build and dyno the motor then decide on a boat
Old 01-04-2007 | 01:37 PM
KNOT-RIGHT's Avatar
750hp
This sounds pretty cool!
With that rpm limit are ya going to run Multi speed trannys?
KNOT-RIGHT is offline
Old 01-04-2007 | 02:27 PM
TopSpin80's Avatar
I'm thinking a 3 speed... paddleshift.. I don't have a clue what the trannies are gonna cost
Pat Wiesman?? maybe he will chime in
Ernie
Old 01-04-2007 | 06:33 PM
Rik's Avatar
Rik
CM
A 525 engine, not drive package weighs around 900 lbs +/- a Yanmar 480 is 1480 lbs without gear or water in the engine.
Big difference and the Yanmar is Longer which would not fit in the 32'A as a BBC barely fits.
Rik is offline
Old 01-05-2007 | 03:00 AM
I got the weight off of mercury's web site. Where do you find that cummins motor ? How much does it weigh ?
yahoo is offline
