Need some help, gimbal ring #6
1 Attachment(s)
Placed this Ad in the wanted section. Have a new one on order but the part is back ordered from Mercury.
http://www.offshoreonly.com/classifi...ct=2882&cat=28 This tie rod mount took a crap and busted the outer housing around the gimbal's lower pin. It turns out that the tie rod end mount was defective from the factory. A close look and you can see the dark area where it was cracked from day one. The crack is by the weld which is a result of not heating both pieces properly before welding. The design also sucks if you compare this part to others. The base plate should be a lot shorter with either an additional spline or the top bracket or clevis closer to the bolts. |
Call Ocean Performance and ask for Mike. They could have one.
1-860-388-6000 |
Call and ask for Byng at marinee machine and replace both. You will have on immediately.
I have 2 paid 800 for both I have early style drives but was
collecting parts for upgrade drysumps.Just need to know pin and rodend I.D. I think I have M&M Machine. |
1 Attachment(s)
Originally Posted by HotPursuit
(Post 2030984)
collecting parts for upgrade drysumps.Just need to know pin and rodend I.D. I think I have M&M Machine. These are Marine Machine. You can tell because there is no name on the equipment. |
Try Marine Drive Inc. Good friend of mine Randy.
O# 352-447-0309 C#954-214-7784 Good luck he has a lot of new and used parts. I like spare parts you never need them once you buy them. |
Try Speedmaster Inc. in Deland Fl. 1-386-734-3133, Galen should be able to help you.
that totally sucksssssssssss did u get her from tnt ? ? I see @ least, do believe there are 2-diff. housings and mounting locations for the tye bars some on top and some on the backside 45* angle can u-confirm the diff. and why the changes etc. dry vs. wet sump or is it specific to application / I love the "MENACE" best of luck! sell / let me know jay 7815489300
Originally Posted by 1CE
(Post 2059385)
I see @ least, do believe there are 2-diff. housings and mounting locations for the tye bars some on top and some on the backside 45* angle can u-confirm the diff. and why the changes etc. dry vs. wet or is it speciic to application
6A upper housing....tiebar on top |
| All times are GMT -5. The time now is 01:37 PM. |
