-   Skater (https://www.offshoreonly.com/forums/skater-42/)
-   -   New to me 36 Skater need set up (https://www.offshoreonly.com/forums/skater/168558-new-me-36-skater-need-set-up.html)
Strip Poker 388 10-13-2007 01:18 AM
Originally Posted by bripar77 (Post 2304445)
Yea I would quess that a Nortech 36' is heavier than a 36' Skater Qtr. Canopy but probably not more than 500 to 700 lbs.
but its prob 20+ mph???
Fast Franko 11-20-2007 09:05 AM
Originally Posted by bripar77 (Post 2302852)
Fast Franko I assume 3 3/4 above bottom means the bullet on the outdrive is 3 3/4" above the bottom of the boat when level? What drive ratio are you running with how much HP and what props?
Yes that is correct-I have an "open cabin" boat (so it's 5-700 lbs heavier & 5-7 mph slower then 1/4 canopy)had 575's 1.5 gear spun a 16 1/2 x 35
new setup is 914hp 900 ft lbs going to still use the 1.5- I want some serious acceleration-Going to use a 16 1/2 x 38 & see what happens from there
Did you talk w/ AJ & see what his setup was? I heard he had around the same power you do & ran close to 160?
OL40SVX 11-20-2007 10:53 AM
He owns Aj's old 36.
Fast Franko 11-20-2007 01:54 PM
I know that's why I thought the best info would come from him-AJ ran 161 w/ the boat his motors were 1000 hp so pretty close to what Bripar has now
Pro1 11-20-2007 08:06 PM
How did u make out with 1.24?
