outboard vs inboard
My experience has been outstanding with the fatshaft 1:87 sportmaster lowers on the 2.5's.
I don't know what your circumstances were with the condition of the sportmasters to begin with and the type (s) of hull that you ran them as well as what pitch props and your level of abuse to them.
Iv'e run many 2.5 ob's from 92 thru 2007, on 28 , 32 and 36 skaters and the most we did was break 2 prop shafts! (and 1 powerhead) Maintenance is key! (Amsoil and Alisyn gear lube help) However once you go to an inboard setup with #6's I don't think you'll go back to outboards! Outbords def give a great bang for the buck, But 710 Ilmors with #6's are a whole different animal!
Iv'e run many 2.5 ob's from 92 thru 2007, on 28 , 32 and 36 skaters and the most we did was break break 2 prop shafts! (and 1 powerhead) Maintenance is key! (Amsoil and Alisyn gear lube help) However once you go to an inboard setup with #6's I don't think you'll go back to outboards! Outbords def give a great bang for the buck, But 710 Ilmors with #6's are a whole different animal!
