Need Skater Trailer Advice
2 Attachment(s)
My Traler For My 32 Classic Has High Bunks In Which Top Of Tunnel Sits On Bunk . Considering Changing Trailer Bunks To Lower Type In Which Bunk Rides On Inner Step . Does Anyone Have A 32 B In Whicj To Measure The Step In Which Bunk Rides On ? My Step In 1.5 " Inches , Is That Enough For Bunk To Ride On ?
Has This Type Of Trailer Ever Been Used On 32 Classic ? Thanks |
I used to have a 32 Skater with the Skater trailer that used bunks in the tunnel. The boat lift I used for 5 months a year lifted the boat by the inner spray rails you are asking about (I think they are wider than 1.5"). I also had a 30 Motion cat with a Myco trailer that used the spray rails to hold the boat. My Myco for the MTI uses the same method. Only problem with type trailer is you have to be dead on when coming on the trailer. Most of the time I need to line it up by hand. Not easy to drive on the first time
Thanks For Reply ! So Do You Think 1.5 " Spray Rail Is Too Small ? The Main Reason I Was Thinking About The Change Was That The Tunnel Bunks Would Be Hard On My New Paint As With Spray Rail Bunks They Would Be Wet .
Does Anyone Know The Width Of Spray Rail For 32 ? |
if you are worryed about your paint ont he bottom dont the system you have now is so much easer to load in the water i would not switch i have hade both and the tunnel is so much nicer
P.M. sent BIG Daddy
| All times are GMT -5. The time now is 04:33 PM. |
